Qudelix is developing a MiniDSP destroyer.
Madjalapeno
NH, USA
IMO, absolutely yes. Or use an industry standard like TASCAM DB-25 (although this would take slightly more space).
Michael
Or at least design it so a standard USB can not plug in there. Make it so the case gives you some sort of lock out. Should also be keyed in some way.
godmax
Germany
@wslee do you plan also to add a digital output, so you could use the great EQ options with an external DAC - or this is too late in the desgin/production process?
voodooless
Netherlands
Would you rather that they make a proprietary connector?
Make... no, use: yes. There are plenty of small generic connectors out there. The trouble is that they are often way more expensive to implement.
Atanasi
If manufacturers like to use the USB-C connector for their own signals, they should implement it as an alternate mode.
voodooless
Netherlands
wslee
Reusing existing connectors for things like this is mostly not a good idea. The chance that users interpret the connector wrong is very high. With any luck, you will not damage the DAC or the other side of the cable. Hopefully, there are some measures taken to prevent misuse.
Yes, you're right. And that's why we leave the VBUS unconnected.
wslee
No, we don't have any plan for that...
Madjalapeno
NH, USA
I understand your concern. But, we already made the decision and design the HW with USB-C.
And plugging other usb cable or charger won't make any trouble or damage, since VBUS is floating/not connected.
Great. I design and engineer medical products, so continually get to bring up issues to EE's. It's what we do.
That's what FMEA's are for.
Good luck, and I look forward to seeing developments.
Jumbotron
Spain
I know there has not been a post in this thread since december 2021, but I wonder when this T71 unit will be released. Supposedly it would be released early on 2022, according to their website.
JRS
Albuquerque, NM USA
Likewise still very interested--in my case for 3 way actives and stereo SW's.
Rednaxela
NL
So I have a miniDSP measurement microphone. Is it gonna destroy that too?
juliangst
Germany
So does this work like a minidsp flex 8?
I was interested in buying a minidsp flex or the topping DM7 and use it with camilladsp but this qudelix looks like a great alternative
Berwhale
I think Qudelix are still struggling to source components. There are some updates (in Korean, but translatable to English in Chrome) here: https://m.post.naver.com/my/series/...68030&memberNo=49910556&prevVolumeNo=33736870
The design has moved on a bit as well...
juliangst
Germany
Berwhale
I still wonder how the USB C to analog adapter would look like. Does it even work like that? If it’s only a surround downmix device it’s a bit disappointing
Presumably Qudelix will be making an 8 channel earphone with a USB-C connector to go with the T71 (like the QX-over earphones that work only with the 5K).
