Qudelix is developing a MiniDSP destroyer.
buz
I think this is strictly a DAC, no ADC
wslee
Yeah - it's potentially confusing. Normally a "4 driver IEM' just means a 4-way internal crossover. I don't immediately see a benefit to the idea of '4 discrete surround channels' each going to a separate driver in the IEM - that doesn't really seem to offer anything over a 'better IEM' + standard DSP.
Another possible interpretation is that they're implementing the 4-way xover for the IEM in the DSP of the unit, and so need the 8-channel output to feed each driver independenly. This would mean doing typical HTRF dsp-downmixing of the surround material to stereo, but it would explain the somewhat odd pairing of 'virtual surround' functionality with '4 way DSP crossover'.
Yes, normally, we have stereo(2-ch) DAC/AMP and stereo wire interface. And an IEM built-in analog crossover circuit splits the stereo full range audio into each frequency bands.
Qudelix-T71 DAC/AMP has 8-ch DAC/AMP and output 8-ch analog audio signal. Qudelix-T71 IEM receives those 8-ch audio and reproduces acoustic wave with each driver.
Of course, we need DSP processings to make the front-ch sound in front, and to make the rear-ch sound in rear.
The difference is that:
7.1 or 5.1ch --> DSP Processing --> Down-mixing into Stereo --> Stereo DAC/AMP ---> Stereo Speaker Drivers
vs.
7.1 or 5.1ch --> DSP Processing --> 8-ch DAC/AM --> 8 Speaker Drivers
Walter
However, for stereo audio sources, Qudelix-T71 provides 4-way active digital output, utilizing the 8-ch HW resources.
If I understand that correctly, this means we will be able to use this as a DSP and active crossover into a 4 channel DAC, similar to a miniDSP Studio without the Dirac. If that is indeed correct, and the price is right, this could be a very interesting product.
Reactions: JRS
wslee
Correct.
Qudelix-T71 tracks the actual incoming audio number of channels, and processes the input respectively.
If stereo input detected, T71 can process 4-way active crossover and output them through 8-ch DAC/AMPs.
buz
Do you have any indication about the pricing yet? (broad price range, really)
wslee
Not yet fixed.
But, the form factor would be:
- ARM + DSP(600MHz)
USB Audio Class 2.0
Stereo 384/32
7.1 or 5.1ch
- ES9219 x 4
8-ch Output directly from ES9219 (up to 2V RMS)
- TI OP AMP
3.5/2.5 stereo output from TI OPAMP
for generic 3.5mm UNBAL stereo output
for generic 2.5mm BAL stereo output
- Rotary Volume Knob
- OLED Display
- Built-in Dual MEMS Microphone
- Aluminimum CNC chasis
- No Battery / No Bluetooth
wslee
BTW, T71 and miniDSP differ from each other in many aspects.
Refer to the below images.
buz
Somehow I am missing the 7.1 connectors on the pictures, will they use a break out cable from the headphone out or how do I use it with speakers?
wslee
T71 uses USB-C connector to output 8-ch analog audio.
voodooless
Netherlands
Too bad there is no analogue or digital input (other than USB). Could make for a fun active speaker DSP otherwise. What are the DSP options anyway? The DSP chosen is not really a standard old school DSP chip. Can you but the thing without the IEM as well?
Atanasi
8-Ch Audio Signal 8 pin go through:
TX1+, TX1-, CC1, D+, D-, SUB1, RX2-, RX2+ (Symmetric)
Is this safe for plugging standard USB devices? It doesn't comply to the USB-C alternate mode standard.
voodooless
Netherlands
I’m pretty sure you’re not supposed to plug USB devices in there. There is another USB input.
Reusing existing connectors for things like this is mostly not a good idea. The chance that users interpret the connector wrong is very high. With any luck, you will not damage the DAC or the other side of the cable. Hopefully, there are some measures taken to prevent misuse.
A
abdo123
Brussels, Belgium
Type-C is incredibly sturdy though and i feel like this is the best compromise for a 8-ch DAC the size of a remote control.
Reactions: JRS
voodooless
Netherlands
It's not about the sturdiness. It's about the fact that it's a USB-C connector that is repurposed for something else. For a DIY project, not an issue, for a commercial product, it seems risky.
A
abdo123
Brussels, Belgium
Would you rather that they make a proprietary connector?
