antcollinet
OK - looking again, what they are calling power factor correction is achieved at the left hand side of the board. I'm guessing it is switching in/out of circuit the two white capacitors using the relays.It is very difficult to see how it can be doing any sort of power factor correction - let alone adaptive correction without (as far as I can see) any active power switching devices.
It seems to have (again as far as I can see) only an EMC filter and some transient suppression devices. And given the wire size on that choke, I'd be concerned about its power delivery capability on 4x 1000W outputs. The only proviso is I have no idea what the two cylindrical components marked LAB12 are. I assume capacitors - but who knows.
Most of the circuit seems to be devoted to power analysis - but not much point in doing that if you can't fix anything.
Needless to say - it will provide zero improvement to your audio.
I'm expecting they can "adapt" 4 levels of capacitance : none, small, large, small+large.
The problem is that this type of correction is used when driving inductive loads (such as motors), by compensating the inductive phase shift with capacitive phase shift. Further, it is intended to correct the power factor of the system seen by the mains supply, not by the connected devices.
It will do nothing to correct the power factor of typical audio kit power supplies, and in any case power factor correction doesn't help the devices which are generating the power factor issue. So, I'm not seeing any benefit for any connected audio equipment in doing this.
