It’s nonsense. It is nothing more than marketing garnished with diagrams. Just a few points:
- It is not counter-intuitive that in a bi-wiring setup the LF cable will carry mostly LF current and the HF cable mostly HF current. The low- and high-pass filters in front of the speaker drivers make sure of that.
- Intermodulation does not occur in cables, it happens in the amplifier, i.e. before the cables split into LF and HF.
- If you put the HF (red) and LF (green) current graphs together you pretty much get the blue curve (single-wired setup).
- A funny bonus: the HF cable appears to catch a mains hum that isn’t present in the single-wired plot.
They’re just hoping nobody will look closely, or check whether their conclusions actually follow from what the graphs show.
I agree with most of the posts above, especially with the 2 from theREALdotnet.
The link from Q Acoustics is well written in general. As an example, see the 3rd paragraph quoted below. The italics are mine.:
Proponents of the practice point to the obvious sonic benefits they can hear after bi-wiring their speakers, citing the fact that speaker manufacturers make the terminals available, as proof that there must be something in it. Detractors argue that manufacturers are merely maximizing the marketability of their products by offering a feature that costs little extra to implement but probably doesn’t make any sonic difference. They also point out that there is no real published evidence to prove that the practice makes any audible difference, whereas the bi-wire enthusiasts theorize that by separating the high and low frequencies into different wires, distortions caused by interactions between them can be eliminated.
Q Acoustics pointed out that "there is no real published evidence to prove that the practice [of bi-wiring] makes any audible difference …" The problem is that Q Acoustics also provides no evidence of an audible difference.
They did provide some unconvincing charts of current measurements. In Fig 6 (bi-wired tweeter cable), an area (at 1-2 kHz) was circled and labeled with the comment "IMD reduced dramatically". I couldn't see any difference between that area in Fig 6 and the same area in Fig 5 (single wired cable).
Furthermore, the background levels of measured IM noise, other than the frequencies of the test tones, appeared to be higher in Fig 5 than in Fig 6, but those measured levels were still quite low, no higher than 40 to 50 dBu lower than the peak of the test tones. Who hears noises 40-50 dB below a signal's sound level?
But, most importantly, Q Acoustics never showed any results at all of listening tests. As a result, they can say nothing at all about possible sound qualities introduced by bi-wiring speakers. This article is advertising copy – not research.
