Lars: Having a super low output impedance does have one real benefit: it makes bi-wiring work. The whole point of bi-wiring is to isolate the tweeter and woofer portions electrically. If you have a common impedance in series with the speaker, distorted currents produced by the woofer will turn into a distorted output voltage which in turn is seen by the tweeter section. So if you want bi-wiring to work its magic you really do need an extremely low output impedance, which is the same as super high DF of course.
Bruno: Good point, a hundred might not be enough then. I think people resort to bi-amping when their amps don’t have low enough output impedance for bi-wiring to do the trick. So for a serious audiophile having really high DF is a real advantage, if only financially.
