GrimSurfer
- Joined
- May 25, 2019
- Messages
- 1,238
- Likes
- 1,484
A few months ago, I participated in a discussion elsewhere on the use of "pro gear" in home theatre. Looking at the respective specs, I saw a reliable correlation between higher THD+N and IMD and pro gear. This was explained by the fact that the majority of pro amps employ Class D topologies. The high output powers involved also necessitated this use of fans which, I contended, raised the potential for audible artefacts in a home setting.
What I've mentioned above are generalities... there are certainly pro amps out there whose specs meet of exceed the levels of marginal consumer gear. The spl goals at public venues also make it more likely that pro gear will offer higher output power (though many manufacturers of such gear quote peak/PMPO, which can be misleading).
To their benefit, pro gear is almost always grounded for safety reasons in open environments. Many accept balanced connectors, which we know can reduce noise when correctly employed. But connecting pro and consumer gear (ie consumer preamp with pro amp) can create challenges of its own. None of these are insurmountable but they do add another layer of complexity/potential problems (ground loops, level and impedance matching, etc.) to the mix.
Other than, perhaps, powering passive subs, my view is that many pro amps aren't the ideal choice for home use. Sure they're inexpensive but the specs reflect an entirely different set of priorities (high emphasis on power density, low emphasis on THD+N and IMD, and very little acknowledgement of fan noise).
I think one of the things that confuses people is the term "pro". Some people equate this as meaning better. I think it's a very general term that is used to describe it's intended use/setting and doesn't necessarily imply anything qualitative at all.
Dollar for dollar, pro amps can appear attractive at first glance... but the cynic in me says "read the fine print... you might get what you pay for".
Thoughts?
Edit: changed double insulated to grounded.
Thoughts?
