AudioStudies
- Joined
- May 3, 2020
- Messages
- 718
- Likes
- 401
- Thread Starter
- #21
check out MarchandHow is an analog crossover "active"?
Simple, it's before the amps but not done via DSP. Instead it's a mix of active (i.e. done using op-amps) and passive filters done at line level.
check out Marchand
Already answered by a couple of people. My understanding/definition is that any crossover that is implemented before the amplifiers is “active”. I’m certain this was done for years before the advent of digital active crossovers.How is an analog crossover "active"?
Does anyone else worry about this, or do I just worry too much?
I'm not that old at 65 I guess. If the crossover is of a passive construction vs active (digital), that's what defines it.
No, it's still active as it's before the amplifiers and uses active filters. It's just not DSP. Active speakers have existed for decades, long before DSP was powerful enough to work as a crossover acceptably.So just not an active crossover?
I think you are mistaken. Perhaps Marchand makes some passive crossover, but for years (and likely still) they made analog electronic crossovers that split the frequencies without any digital processing.I've checked them out before, they're passive, not active.
Active =/= DSP based.Yes, because they are of a passive design, not digital. They're famous as an alternative to a digital/active crossover.....
Yes and no. If you care about latency, DSP is never a good solution because you inevitably add 5+ms of latency between AD-DSP-DA. Otherwise, little concern to speak of.
An active crossover splits the frequencies prior to amplification of the drivers, and thus differs from a passive crossover network that an amplifier must drive through before the signal reaches the driver. I am pretty sure that active analog crossovers have been around long before digital signal processing was invented. Active does not necessarily mean digital.
Far as I can tell, the first analog active crossover was 1967. No way was computing advanced enough to do high fidelity audio DSP of any sort.I am pretty sure that active analog crossovers have been around long before digital signal processing was invented.
I mean, if you're in a situation where you need the lowest possible latency it isn't great. Doing overdubs where the artist is in the room with you for example is not a situation I'd want any additional latency. Not a problem in home audio land (usually, HT it can be), but in pro audio land it is something people care about.It's a good thing that you bring up latency. Nowadays, youth are not accustomed to waiting for anything, so 5ms of latency is likely to be a dealbreaker for anyone born after a certain year.
https://en.wikipedia.org/wiki/Audio_crossover#:~:text=Active crossovers are distinguished from,to a separate loudspeaker driver.
The Wiki link on crossover can hopefully make it clear that a crossover does not have to be digital to be active. Certainly an active crossover can be digital, but not all analog crossovers are passive, some (like many of the Marchand products) are active.
For the most part, I am in Home Audio land, so perhaps I shouldn't worry. My HT is done in stereo without surrounds or center (for the moment).Far as I can tell, the first analog active crossover was 1967. No way was computing advanced enough to do high fidelity audio DSP of any sort.
Just put it to rest. I know what an active crossover is, and I have told you. I have even explained the difference between an active and passive crossover. If you don't like Wiki, please do your own research. Like @dfuller stated, the first analog active crossover was in 1967, long before DSP existed. You are free not to believe me, but I can't explain it any better than I have, so please just drop it.Haven't looked yet (let alone veracity of a wiki) but how does it make any passive crossover not "active" in that sense? Simply lack of direct amplification post-crossover? That's "active"? Seems another form of passive crossover to me.....
