SoundSloth
- Joined
- Feb 11, 2024
- Messages
- 3
- Likes
- 0
I’m on a mission to find an AD/DA converter and monitor controller. I would prefer an all in one solution, but am fine splitting between two units if needed. Looking to keep in a budget of ~$2500, but am able to get 20% off a fair amount of stuff, so this helps the budget go a bit further.
I’m trying to feed one set of speakers and an analog processing chain simultaneously and return the processed signal back into my DAW via the same unit. I very much want dim and mono controls on the physical unit itself and not have to dig in software for this function. The Amari seemed dang near perfect for this, but I just found out the analog outputs are not separate like on the Pure 2, so the dim, mono, mute and volume functions would also affect the signal going to processing.
On the AD/DA converter I would like USB, AES and Analog in with two separate analog outs. As I mentioned I’d wouldn’t mind splitting this up between two units, but I’m not sure it would be possible on my budget.
Any one have any thoughts on this?
Thanks.
Thanks.
