- Thread Starter
- #61
I could sell people empty boxes shipped from China for $200 and still loose money! This is a tough, tough business.
If so many of the sub $700 speakers have such thin wiring from the crossover to the speakers, why do some people still spend so much money on speaker cables? If you got a pair of $200 cables running to $700 speakers that have $.96 worth of wire on the inside what's the gain from the cables? I think more consumers need to see what's inside their speakers before purchase or the front falls off.
expect this would have been a better speaker if both woofers were located under the tweeter. Certainly it would be if the crossover took the so-called 2.5-way approach where the lower woofer rolls off at low frequency a couple of octaves or so below the crossover point.
This speaker is really odd.
On one hand, building it to this price is little short of miraculous.
But on the other, for no additional effort or cost it could have been so much better.
As noted above by others.
Built it as a 2.5, not an MTM. (OK this does add crossover complexity.)
Add a waveguide to fix the top end. That just involves redesigning the existing plate.
Fix the FR tilt.
Do this and the speaker could be a giant killer.
It starts to get to the point where speakers should have a switch on the back that engages showroom mode - just like TVs do.
Well...Uhhhhh
You, sir, have a future in the audiophile industry!It starts to get to the point where speakers should have a switch on the back that engages showroom mode - just like TVs do.
This is a review and detailed measurements of the Polk Monitor 40 Series II bookshelf "MTM" speaker. It is on kind loan from a member and costs US $200 on Amazon for a pair including Prime shipping.
The Monitor 40 looks pretty decent for such a budget speaker:
After decades of surviving in brutal consumer market for speakers, Polk knows what it is doing here. And that involves super lightweight design and shoddy construction that allowed the front baffle completely separate itself from the enclosure in shipping!
They have a rabbet all around which provides for large surface area for the glue and air tight construction. Why did they resort to these wedges that gave out due to weak fibers in the MDF? A couple of screws would have helped keep it there as well.
At least there is some foam inside:
They put money toward bi-wiring terminals that no one uses but likely checks a box for marketing:
I performed over 1000 measurement which resulted in error rate of less than 1% or so.
Temperature was 68 degrees F.
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
Reference axis was the tweeter center.
Polk Monitor 40 Series II Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
Lots of issues here starting with tweeter frequency not being flat and elevated. The woofers are getting more directional before tweeter takes over and presents a wider dispersion. Near-field measurement shows the many flaws:
We clearly see the issues with the tweeter but also the port letting out a resonance right at the crossover. The woofers are allowed to play up to 5 kHz making me wonder if the filter for it has too little slope.
Early window response has no choice but to be messy:
Summing these produces an estimated response in your room that is likely to be quite bright:
Bass response is low which helps keep distortion in check especially given the dual woofers:
Horizontal beam width is not pretty as we could already guess from the spin graph:
I think this is the first MTM configuration speaker we have tested so its classic dispersion is nice to see:
Edit: forgot the impedance and phase:
Polk Monitor 40 Series II Listening Tests
Oh wow, this speaker is bright! High frequency notes literally jump out of the speaker and meet you half way! I must say, I can see the appeal of that in a showroom and with casual listeners. Bad choice to throw at me though as I am super sensitive to high frequency accentuation (spent so much time training to hear distortion in them). So I had to pull out the parametric EQ tool in Roon right away:
This is a quick and dirty correction to make the sound bearable. It was still bright but likely if you add a sub, it would balance it out.
Power handling was excellent because there is essentially no sub-bass reproduction so my killer tracks of this kind did not do much to Monitor 40.
The Polk Monitor 40 Series II is a great example of what you have to do to bring the cost down to crazy low yet keep the showroom appeal high. is this the most broken thing Polk could design? No, that would require a lot of distortion as well which I did not find. Still, without equalization and lots of playing around with that I don't see this being a useful speaker to live with, monetary savings be damned. Eat less outdoors, save the money, and buy something better please!
I can not recommend the Polk Monitor 40 Series II.
Had a miserable day yesterday. Why is it that all plumbing work is hell? We spent a fortune to have a yard guy dig trenches in our orchard for sprinklers. We were not here to watch the guy and he used the thinnest PVC tubes he could to save money -- much like Polk above. Worse yet, didn't know much about plumbing and created many sources of water leaks. This is the second time I have had to dig a ditch 3 feet down in thick mud and clay.I could barely expose the failure point and have to dig more to make space to fix it. So more muddy miserable days are awaiting me until I get this thing fixed....
Polk Monitor 40 APO EQ Score 96000Hz
June152021-104327
Preamp: -2 dB
Filter 1: ON HPQ Fc 72.30 Hz Gain 0.00 dB Q 1.23
Filter 2: ON PK Fc 128.00 Hz Gain -2.66 dB Q 1.46
Filter 3: ON PK Fc 259.38 Hz Gain -1.45 dB Q 12.00
Filter 4: ON PK Fc 452.00 Hz Gain 1.42 dB Q 2.31
Filter 5: ON PK Fc 770.50 Hz Gain -1.14 dB Q 2.90
Filter 6: ON PK Fc 1351.17 Hz Gain -2.81 dB Q 6.24
Filter 7: ON PK Fc 1631.00 Hz Gain 2.60 dB Q 2.43
Filter 8: ON PK Fc 2666.50 Hz Gain -1.25 dB Q 3.33
Filter 9: ON PK Fc 5796.00 Hz Gain -3.10 dB Q 1.36
Filter 10: ON PK Fc 13017.00 Hz Gain -5.24 dB Q 2.39
The Polk R200 managed the second highest preference score of any passive bookshelf with publicly available spin data (calculated by @pierre based on measurements by @napilopez). I'm not sure why so many people want to pass judgement on Polk as a whole based on one of their cheapest designs.Not a surprise, sadly. Nearly 40 years of underwhelming “performance” in my experience.
Agreed...the smell of 'haterade'The Polk R200 managed the second highest preference score of any passive bookshelf with publicly available spin data (calculated by @pierre based on measurements by @napilopez). I'm not sure why so many people want to pass judgement on Polk as a whole based on one of their cheapest designs.
I'd get more experience.
I love my old late 80's Monitor 5jr+ and 4 speakers, also those little front-angled ABS housing "Polk Monitors" sound quite good in smaller rooms. I fear that Polk is not doing a good job of holding on to what made them good/great in the first place. I think I paid $300 for the 5jr+ speakers back in '87, that was a lot for me then. They have held up extremely well.
YupI'd get more experience.
From the currently made ones, the Reserve line has been getting some positive feedback. Hoping Amir will test one of them soon.Do you have any models or model ranges you would suggest a buyer should familiarize themselves with? While I am not in the market at the moment, some here might be.
