watchnerd
i can swear the all analog lp's sound better then either regular lp's and digital.
If they do, it has little to do with the format.
Mastering artistry matters a lot.
is there something i'm missing here?
from what i see, most ppl have a 2000$+- speakers setup.
you are saying that the onl;y thing affecting SQ are the amp and the speakers.
so why the hell would someone spend 700$ on DAC and PREAMP each?
wouldn't it be much better to get a 4000$ speakers set up, a 50$ Preamp and 50$ DAC?
in addition, few folks here said that there is no superior in analog sources on digital; i'm sorry, but I can definitely tell the difference between my analogue production lp's to my digital media, no matter if its 192 or DSD, and i use a very budgety TT. am i imagining?
interesting. so if i get you right, digital files with poor noisy DAC will sound to me like vinyl?Essentially, yes. Maybe $100 per unit if you wanted to be extra cautious (paranoid IMHO) about not potentially adding any audible noise/distortion with the DAC/preamp, or more than $100 if you wanted special functionality (e.g. balanced outputs, EQ, etc).
It's very likely there's a real, audible difference, but that you prefer the noise and distortion that the TT adds. You definitely wouldn't be the only person with this kind of preference
There is also going to be a psychological component (as there always is when it comes to these things), but it won't be possible to work out exactly what influence it has without elaborate controlled testing.
I thought The same when I had passives, but that all changed when I got some active speakers.i can swear the all analog lp's sound better then either regular lp's and digital.
thought about that, so i've downloaded digital versions of those masterings, and yet, the vinyl sounds better....
and what would be the explanation for that?I thought The same when I had passives, but that all changed when I got some active speakers.
"Better" may just mean that the LP playback experience suits your taste.
I like LP playback, too, for the extra LP-specific characteristics.
But I also have reel to reel tapes, which would be the original source for any 'analog only' LP, and in every case, the LP is an inferior reproduction of what is on the original analog master tape.
Whereas digital can represent *exactly* what was on the master tape.
i feel so **cked up for spending 3K$ on TT, LP's and that Gustard. -___-"
if you find your digital collection to sound better, why would you want to listen from all those analogs?
i'm considering buying actives (genelec 8030) everybody says its more bang for the buck.
got it.
and more practically, shall i return my gustard before opening it? it has nothing to offer me besides MQA, (and i've already switched to qobuz from tidal) i cant hear any noise from my motherboard DAC.
I'd second actives for value. Love my JBL 708's and 705's... And my little Audioengine's.
No reason to tell yourself not to enjoy them for all the reasons the rest of us do. I probably have $6k spread over 4TT's and a handful of cartridges, and 500 or so records (they are fun to collect) worth probably twice the rest of my gear combined.
It's not about the SQ... (Ask @watchnerd , he's heard rips from a couple of my tables).
sorry, my English isn't too good as i guess all of you have already noticed.
"second" means reconsider? of second choise, meaning actives are better.
All, I think we are not being very helpful to the young man.
So, let's cut it down and be practical.
You are so great!
1) He has ordered a Gustard x16 DAC.
Does that seem like a good quality and bang for the buck choice?
Yes, I think we can agree on that.
2) Will he even on this current system hear a significant improvement playing the DAC give a well recorded/mixed/mastered.
I think that is still a yes.
they all agreed DACs doesn't affect sound quality at all.
3) Will any of the discussed Genelec active monitors give him a significant increase of sound quality over his current system.
Sanyo DCA 411 + Sony sscs bookshelves
Yup
4) Will he need a preamp or some switch gear/ source selector if he want to play both DAC and TT without unplugging from any actives.
Yes
5) Will the mentioned Swissonic M-Control + passive monitor control with 2 inputs be a a resonable choice?
Yes, especially if it has transformers in RCA - XLR chain or have them added.
i guess a chain means something that will bring a real balanced output? how can i add it?
6) Could another approach like just upgrading his passive speakers also give a significant improvement?
Yes it could, but the end cost for a similar result will likely be more expensive.
regarding both 6) and 8) few people said that monitors are more a work tool for mixers and less enjoyable, so maybe that is a good option, and no need for all the XLR preamp mess.
7) Anything else that could improve the experience, given the discussed upgrade?
Sure, a sub if not included, some room treatments (need not be expensive), careful DRC (digital room correction).
what room treatments and DRC?
8) What are we forgetting???
MUSIC
Isn't it all about just enjoying the music?
Enough tech talk . . . . .
Tap that foot
Smile
Peace out.
Thanks
