I don't see it...yet. The different cartridges with very different response give the same difference signal >300 Hz. It should not if cartridge error is a factor.It’s chasing two unknowns.
Can you test another test record and analyse as in post 524?I think I did this in post #532, but without shifting back. See the blue response.
I took 1KHz and compared it with 1,35KHz and so on.
The dip at around 230Hz is due to torsion of the tonearm.
I'll have to think more. I was thinking if you have the perfect test record, all deviations should arise from the cartridge both at 33 and 45 RPM. Question: are the curves identical, i.e. do the peaks and dips occur at the same frequencies? If so, the difference signal should be constant vs fr (?)Very little error for both the record and cart below 1kHz coupled with the FFT resolution.
Cart error has to be a factor. If the cart has an error that you know exists at 45 from the 33 level then you have to correct is at that F for 33 or you'll compound errors. I think this is why the error curve always looks very similar, or a contributor to that.
Thanks,Here are two plots with different test records. Again, I think the blue plot has to be inverted and represents more or less the frequency response.
I think it is needed but I might have it backwards A potential peak at 10k corresponds to the record level at position ”33 RPM 7407 Hz” (ie 10k at 45 RPM) minus level at position 10 kHz (reference @33 RPM). I think. So it has to be shifted back, 0.74x.Nothing is shifted. It is red-yellow as shown in the graph.
The difference curveWhich trace you think should be shifted back? I could do it in the software.
Yep. The wiggles are the transient changes, pairwise comparisons. So it shows where there are changes but level returns to zero as soon they are the same. So it is the ”derivative” and tell you something about what is happening but not the record fr response.I got it now.
If we assume that the frequency response is raised by +1dB above 1KHz til the end of the sweep, we will see this for a short time in the crossover region, but not after that. The difference would then be 0dB above 1KHz. It will not work.
The problem with the method is that it is pairwise comparisons on the record. If there is a +2 dB peak at 740,7 Hz and +2 dB 1000 Hz on the record, the relative difference will be zero. So you will get errors. I guess the average difference curve of 33 vs 45, 33 vs 16, 33 vs 78 would take some of these errors out. Spin down methods as JP did is other options.
Regarding the wiggles I get om my ATPTG33 with ClearAudio TRS-1007, but not with ATOC9ML/II. I definitely occurs every rotation, I calculated the time vs frequency /roitation interval. The valley occurs at frequency intervals that match the rotation, and I can visually se the cartridge wiggle. Soit may be some kknd of "scrubbing effet .the cart goes up/down and the relative frequency/velocity changes. So maybe PTG has a disadvantage related to bumps that the OC9 does not have? ,puzzled. I will try to chage tracking force and VTA and see. Maybe the SME fluid damping will help?I use a record flattener like record pi or vinyl flat.
I wonder now if some of the oscillations may have to do with insufficient tracking force.
