Phono Cartridge Response Measurement Script
Distortion is starting late in 1k mode. At least on my computer.
s
Starting point L -24.44dB, R -35.79dB:
My third adjustment was the best I achieved with the Ortofon record, though my target was to optimize on the JVC:
  • Ortofon L -31.28dB, R -30.60dB
  • TRS-1007 L -27.78dB, R -30.49dB
Final adjustment #6:
  • Ortofon L -34.43dB, R -29.68dB
  • TRS-1007 L -29.68dB, R -29.30dB
  • XG-7001 L -28.23dB, R -24.73dB (EDIT - Pilot tones from sweep tracks)
  • STR-100 L -19.69dB, -19.85dB
  • *EDIT* XG-7001 B Tracks 5 and 6: L -29.95dB, R -29.68dB
**Note the FR looks strange on XG-7001 as I used RIAA bass emphasis which is not correct for this record.
Just a question; how did you adjust it? CW or CCW seen from the front? I am not sure yet if my cartoon for phase and azimuth is correct.
Single file plotstyle 1 gives this error (at least for me):
Traceback (most recent call last):
File "C:\Users\Fran\anaconda3\lib\site-packages\spyder_kernels\py3compat.py", line 356, in compat_exec
exec(code, globals, locals)
File "c:\users\fran\desktop\test\jp 16.1.py", line 529, in <module>
lines2, labels2 = ax2.get_legend_handles_labels()
NameError: name 'ax2' is not defined
I know I changed some things so I tried it with a clean copy of the script. The other plotstyles work.
Anyways, there goes my weekend:
Always breaking shit.
Towards the bottom of "if plotstyle == 1:", change:
Code:
else:
            lines1, labels1 = ax1.get_legend_handles_labels()
            plt.legend(lines1 + lines2, labels1 + labels2, loc=4)
To:
Code:
else:
            plt.legend(loc=4)
I noticed the filter at 10Hz doesn't appear to be affecting the fundamental plot, it is affecting the crosstalk plot. I'm going to remove that feature as I think it's going to cause far more trouble than it'll solve.
AT150MLX. Different body but same inductance so it shouldn't matter. This is the lowest high frequency bump I have been able to produce. Seeing that my alignment seems right, this is the best I can do. If these results hold, 50pF total should be perfect, lol.
I am liking this crosstalk feature (on test records like this) as it keeps you honest. It's also a fabulous set-up tool. Not sure if this is the limit on this record, however. Spec is 30dB. I'll try it again when I get the original cartridge body back.
Side B of my Clearaudio CA-TRS1007 is different...seems cleaner vs. side A in left channel. But x-talk is poor.
I've been playing around with my Denon PCC test record and my AT132/ATN152 combo, trying to get it to do 40dB+ of separation again by means of active compensation. First step is to measure crosstalk as is, of course. But I noticed something weird. LtoR crosstalk was only at around 20dB, while RtoL was about 32, just like it used to be for both channels the last time I measured. I didn't use it for about one year but it did not get damaged. Does anyone have an idea what might cause this? The preamp I use is different than last time, though I can hardly imagine it being bad enough to cause that much crosstalk on only one channel. Pretty odd.
What was your initial and azimuth-adjusted crosstalk initially?
This script is fantastic! How are people preparing their wave files from the DENON XG-7001 record? I gather from the thread that they need to be filtered/EQed?
The most likely cause is simply that something moved. Maybe the body, maybe the cantilever azimuth?
It requires custom bass emphasis. I've not dug in to that yet - I need biquads to implement it.
First round of CA test record flattening. Nothing too strong. But I think all my results show a tightening up of the some of the harmonics. Ignore the color changes, as this record provides messy results I am playing around with colors that are easier for me to differentiate.
Thank you. So, should I be seeing a falling frequency response in the graph using default settings, down -10dB from 1kHz to 10kHz? Or is there something else that I’ve messed up?
