Hi all,
I was asked to comment on this thread, so thus I am...
First, let me start by noting here are links to the measurement file and the results:
PDF of results
APx Measurement File
Those with APx units (v6 software) can run the project themselves; for everyone else, the PDF shows the configuration and the results.
I did some quick stepped sweeps: 20 Hz to 20 kHz, 61 steps. I ran it with two sweep levels: -1 dBFS and -15.45 dBFS. The second setting corresponds to an industry-standard (EN50332) 179 mV RMS output from the device. Thus we're measuring effectively at full output and at "normal" output levels (179 mV into a 32 Ohm load corresponds to 1 mW, and that's what EN50332 bases things around).
All measurements taken on my APx515, with a pair of our
Ti IEMs connected (32 Ohm loads). We find the following:
Max output voltage is approximately 1 Vrms. Into a 300 Ohm load, you will get just about 3 mW (p = V^2/R). However, there are precious few portable audio headphones with that high of an impedance; most are in the 16-50 Ohm range (note: we're a portable audio company; we don't build gear targeted towards home use, but stuff you can use when you're out and about).
Looking at page 4 of the measurements (remember, these were run with a 32 Ohm IEM attached) we see it generates 1 Vrms. That would be about 30 mW (p = V^2/R, 1*1/32 = 31.25 mW), not 7 mW as stated earlier.
At a -1 dBFS sweep, we see on page 5 that THD is below 0.008% THD down to about 250 Hz, and slowly rises below that, to 0.05% THD at 20 Hz. This is at 31 mW output into a real load; the Ti IEMs are 106 dB SPL @ 20 Hz at 1 mW, so this would represent an output level of 120 dB SPL. Rather loud, I think most would agree.
Page 8 shows the 3HD for the unit, swept from 20 Hz to 20 kHz, at that same -1 dBFS level. We see that it is the main driver of THD at the high output voltage; this is an effect of current pumping and we've done the best we can, within the constraints of the size and budget, to minimize that. However, 3HD is 0.005% at 1 kHz, and 0.015% at 100 Hz, despite our best efforts.
Page 9 shows the SINAD (basically S/N + THD) of the system. It's pretty good, being > 80 dB until the deep frequencies (where our sensitivity to THD is reduced). I would like it to be better down below 100 Hz, but we would have had to add some pretty big film caps and more shielding, both of which would double or triple the size of the USB end. And we deemed it better to stay small and pretty good down there, versus being a lot bigger and better down there.
Pages 10 to 16 repeat the measurements, but at the -15.45 dBFS level. On page 11 we see the result - we have 179 mV RMS output (EN50332 compliant - 1 mW into 32 Ohms). Page 12 shows THD is a bit higher across the band, but lower in the bass range. This is an effect of less voltage stress on the capacitors in the audio path - they're not pushed as hard (high voltage, film caps would help here - but those are quite large and expensive for the size of capacitor we need). So while midrange/treble THD "rises" from 0.005% to 0.01%, bass THD drops from 0.05% to 0.02%. And note - this measurement is a LOT closer to where you'll be listening.
Page 14 is also pretty instructive. This is "just THD" - no noise. Here we see THD at 1 kHz is 0.0035%! So at the lower output level (179 mV, not 1 V), our THD+N is dominated by noise. Not really a surprise; it doesn't take much noise to generate 0.005% when your output level is less than 200 mV! So at normal listening levels, we'll have a higher noise floor, but the THD is really non-existent for pretty much all the range, not breaking 0.008% (rated) until 80 Hz.
Page 15 also shows a pretty significant thing - 3HD is quite a bit lower at the 1 mW output level. At full output, 3HD drove most of the THD; here we see it's less than 1/5th of the THD. Again, this is voltage-on-cap based issues, and shows that at usual listening levels, the THD is not just low, the dominant odd harmonic (3HD) is a LOT lower and essentially a non-issue.
The last page, page 16, shows the "big picture". SINAD is quite a bit better, not really changing much at all in the mid/treble, but significantly improving in the bass range, gaining over 10 dB down below 50 Hz.
So, to sum up, Rhodium:
- can output 1 Vrms into a 32 Ohm load
- will generate 3 mW into a 300 Ohm load, and 30+ mW into a 32 Ohm load
- will have < 0.008% THD @ 1 kHz @ 30 mW output (1Vrms into 32 Ohms)
- has even better performance at typical 1 mW output listening levels
- was designed so that tradeoffs benefitted typical listening levels rather than rarely-used full output levels
- is not optimal for high impedance, large/inefficient cans
- is extremely portable
Oh, lastly: we use the ALC5686, not the 4050 as shown in a previous picture. It's a bigger package (6mm x 6.5mm) but with finer pitched pins. We also have a higher tolerance oscillator, and selected every cap in the system with an eye towards superior performance in the small package, but when tradeoffs arose we chose to give priority to typical listening levels (-25 dBFS to -10 dBFS) rather than full/max output (0 dBFS).
I hope this is instructive; for anyone wanting additional tests or information about our APx setup, please feel free to ask.
Dan Wiggins
Periodic Audio Inc.
