Some software stuff i did so far:
Operating systems:
I wanted to have 700GB of my 1TB SSD for Windows for games, and the rest for Debian Testing as my daily driver. To do that i started a Debian testing+firmware boot stick, entered a repair shell and started fdisk /dev/nvme0n1. I then created a GPT partition label and two partitions, first with 700GB, and a second with the rest of the space. I then deleted the first and wrote everything to disk.
The idea was to install Windows into the free space, it's setup would create the EFI partition and all that. So i did that and it worked. I installed Windows 11 Pro, for which i bought a shady license for 25€.
Then i booted the Debian USB drive again, this time to install. However, it's important to boot the UEFI partition from USB, otherwise you can't install Grub into the EFI partition. I used the large partition at the end of the disc as ext4 for root, no swap. The Intel AX210 wifi card was automatically detected and the install went through in 10 minutes or so (Debian system + KDE + ssh server).
Once the installation was done, i had to boot into the mainboards firmware and disabled the bootentry for windows. Then i booted into Debian and put this into /etc/default/grub:
GRUB_DISABLE_OS_PROBER=false
Then i reinstalled Grub:
update-grub
Next time you boot into Debian you can select between Debian or Windows.
Problems:
- The system used 110W with display at idle in Windows and Linux. I went into the firmware and activated an eco mode, it seems to restrict the CPU to 45W TDP or something like it. I did the same for the display, activated a power saving mode. Idle power usage went down to 70W for computer and display.
- Once i cold booted into Linux, the wifi card would not work. A reboot would fix the problem. It seems Windows doesn't really shut down properly but enters some kind of suspend-to-disk mode. This means the firmware for the wifi card isn't resetted properly. You have to type "powercfg -h off" into a command prompt in Windows as administrator to disable the suspend-to-disk. This means Windows needs a second longer to shutdown and start up, doesn't matter to me.
- Was sick of my old Dell keyboard, ordered a Cherry MX with red silent switches and background LEDs for 80€. It's fine.
Todo:
- I need to look into the CPU power saving features again, not sure if they limit the CPU during gaming. I think i need to look into "Ryzen Master" to get the most out of the CPU.
- I'm sure there is a bit more power to save in Linux, i need to look deeper into powertop and ways to save more power on the graphics card. Right now the card alone uses around 7 watts.
- The AMD boxed fan is loud. I need to look for something better. The case fans are loud as well, again, i need to look into silent fans.
- I need a burner that burns 100GB m-disks for proper backups (so far i only did redundancy, was lucky so far).
