- Thread Starter
- #21
Ah yes this is probably the best option. I think @IAtaman wants to take measurements with REW on a computer, in which case you'd need one of the Zoom models with a USB interface like the H4N.If you want to stick to plug-in power with stereo mics, I've used both the Zoom H1n and the Rode AI-micro (with a splitter like this, as the latter can't power a stereo mic from one input only : https://www.thomann.de/fr/soundman_splitter_adapter.htm).
I've always found your posts extremely informative, especially your explanations of research. Do you have your own measurement equipment, and any interest in trying out the K245 headphones?
They have a bit of a give if you like, but I'd not call them loose. Will take a photo tomorrow.
I really enjoy them. They are the top pair in my rotation by "hours on head" metric since I got the new pads . I'll be leaving for vacation soon and these will be coming with me as well.
I have no idea. I am literate in electronics but not in acoustics. All measurement I see are stereo so I thought that is what's needed. Plus, maybe my left pinna is a bit bigger or a bit flatter or a bit different then the right one that might be significant in some way or another, so get a pair while you are at it I figured . You gents think a pair will not be necessary?
My plan is to measure HD600 on my head a few times and make that my reference to compare it to other headphones, starting with K245s with Brainwavz perforated pads. I have a few more headphones so I thought maybe I might even be able to build myself a larger set of reference measurements to at least have something to refer to when adjusting tuning.
Those Primo EM25s look good to me. I will order a few and play around with them. On the link you shared, it says Primo suggests the EM258 as a possible replacement for the Panasonic WM-61A. I found Panasomic WM-61A online as well. Shall I get those two, are they better in any way, or maybe more standard?
Dayton Audio also has this iMM-6 calibrated mics. They are like $20. Maybe I can get that and use it with the calibration file it comes with which might make life easier?
Ok I'll measure my ones (both physical dimensions and FR).
You only need a pair if you want to take consistent measurements of both ears. Otherwise you will be constantly swapping a single mic between your ears and you won't be able to replace it in the same position each time.
I say do what you find interesting, when the aim isn't to create an industry standard database but instead experiment and share I don't think it matters too much.
You will have to look at spec sheets to decide, though I honestly don't think it matters too much (Primo, WM-61A).
I don't know about the imm-6, besides, how would you get that in your ear?
