- Thread Starter
- #81
I will try harder. And i will try harder than today, my dude.Try a little harder
Tomorrow!
I also think it's GPU related. Sending everything back is a bit overkill though I can understand the disappointment.I reckon it is the GPU. If it was the PSU it probably wouldn't boot at all, if the MB then you wouldn't be able to run headless. I suppose it could be PCI-E slot, but never heard of problems with that before.
Probably you've checked this ages ago, but is MB set to use GPU rather than IGP in BIOS?
Yes, and there is only one choice, which is PCIe.Probably you've checked this ages ago, but is MB set to use GPU rather than IGP in BIOS?
None that i could see, there is no log or last fault state or anything i could see.@TheBatsEar whose there any message about hardware reset when you menage to get into bios? Did you updated it?
What is the alternative if you don't know what the problem is?Sending everything back is a bit overkill
It's an independent graphics card. Neither the mainboard nor the CPU have graphic hardware. Aren't those called GPU?I'm a bit confused with the term "GPU" as it's being used. Do you have an independent graphic's card (GPU) or are you using the IGP (Integrated Graphic Processor) of the AMD CPU?
220W for the GPU, 65W for the CPU. 550W should be more than enough and it even booted with my old 400W PSU. It also was stable for a few hours of Cyberpunk2077 and Scorn.I think other folks may have said this, but grab a better power supply. You won't regret spending a little bit more for upgradability, longevity, and stability.
If i knew i would have been able to repeat it. It's possible that there was more than one problem. Again, i tried to debug this problem for probably 20 hours.what did you do before it
It’s not so much the overall wattage, but the tier of power supply. That being said, if you are using it now and it’s working then have at it.It's an independent graphics card. Neither the mainboard nor the CPU have graphic hardware. Aren't those called GPU?
Yes, something like a Seasonic power supply would be nice.It’s not so much the overall wattage, but the tier of power supply. That being said, if you are using it now and it’s working then have at it.
Once the nonworking combination is sent back, i'll order something else. I'll listen to your advice and get a slighty fatter PSU.That being said, if you are using it now and it’s working then have at it.
Good call. Grab a higher end Corsair or Seasonic. Tom’s Hardware has good articles about them.Once the nonworking combination is sent back, i'll order something else. I'll listen to your advice and get a slighty fatter PSU.
