I guess it doesn't make sense to try to talk to you, so I'll talk a little bit at you.
It seems you really don't see the point. you're missing the gap between what you say—stuff like being 100% behind whatnot objectivity, and how THEY should compare some gear—and how you seem to conduct your, sorry to mention it again, "listening test".
And even though I still admit that I LIKE this amp, and, believe it or not, don't care that you DON'T LIKE it, I still consider it to be a ridiculous attempt of a evaluation or conclusion. It may pass as opinion.
I've just caught up on this portion of the thread, and it seems to me you've been talking-at (as opposed to talking-to) ever since you started posting in the thread.
As for
@amirm , it appears you are accusing him of hypocrisy or a double standard. I get why you might see it that way. But it seems you are missing an important point he is trying to make: a listening report that confirms or is consistent with a measurement and a well-known causal relationship, is different from a listening report that contradicts a measurement or would seem to confound a well-known causal relationship (or posit an unknown or unproven causal relationship).
So if an amp is measured as lacking power, for example, it is not only reasonable but also totally unexceptional that a listening report would indicate that the amp could not drive speakers to a given volume level without audibly distorting or otherwise running into audible difficulty.
On the other hand, if that same amp were reported to sound better than other amps, that would (a) contradict the measurements, and (b) appear to confound a well-established causal relationship between sufficient power reserves on the one hand, and distortion-free sound reproduction across the frequency spectrum at decent volume on the other hand.
It doesn't mean that amp does not in fact sound better to you (or whomever). But it
does mean that if you want
anyone else to think that if they heard or bought the amp they would feel the same way you do, you will have to (a) be very specific about how exactly it sounds better to you, and (b) posit some kind of reasonable explanation for how or why it might sound better.
If you do not do that, then the de facto position of Amir (and many others here including me) is going to be that your listening report is not false or wrong, but rather
meaningless to us. If you posit a testable hypothesis for why the amp might sound better, then you will get a more positive or open-minded set of replies.
If you don't like that, that is of course your prerogative. You're free to leave this forum, or stay here and complain, or whatever you like. But if you decide to opt for trying to prosecute an accusation of hypocrisy against the site's owner, you should not be surprised when your prosecution gets little traction or little sympathy from many members here.
And if, following that, you decide it might be appropriate to trash Amir and the general culture here as close-minded and just looking for clicks/hits, you are of course free to do that too - just keep in mind that if you do that trashing here on this forum, eventually you might get removed. (I have zero knowledge of what Amir might or might not do in such a scenario - just speaking in terms of what's possible.)
