https://github.com/jaakkopasanen/AutoEq
Convolution Equalizers
Convolution equalizer is the most powerful type of equalizer software. These equalizers allow extremly precise control over the frequency response and the results are the same on all devices and platforms when using the same FIR filter. Convolution equalizer is the preferred way to use AutoEq results.
AutoEq supports convolution equalizers with FIR filters as WAV files and with EqualizerAPO's GraphicEQ filter type. The default results contain FIR filters for both 44.1 kHz and 48 kHz sampling rates. Other sampling rates are supported but not given in the default results. EqualizerAPO's GraphicEQ works with any sampling rate.
To use the FIR filters, download the appropriate WAV file and import it to the EQ software of your choice. Please keep in mind that not all EQ softwares support convolution. Some equalizers can load multiple FIR filters at the same time. Download both WAV files, create a Zip file containing both and load the Zip file to for example Roon.
The process is easy in room just show roon zip file of wav files downloaded from this website for specific headphones and enable convolution filter.
Tried with couple of earphones/headphones had mixed results acc to my taste though
