OMG, the forum was offline for an update...
MakeMineVinyl
Santa Fe, NM
tomtoo
Germany
YOU HAVE HURT MY FEELINGS!!!!!!! :facepalm:
AdamG
Moderator
Reality
AdamG
Moderator
Reality
I disabled all the "reactions" and reverted it to the old "Likes." Review page is also dual column again.
And you added the like counter back to the Avatar window. As it was before. So thanks Amir!
voodooless
voodooless
Netherlands
So no feelings after all then ;) oh well, I guess we’ll stick to the science then.
Dual column is much better indeed!
Matias
São Paulo, Brazil
Phorize
U.K
Oh, I found another annoying thing: you (at least by default) no longer see the number of likes somebody has. It used to be below the messages count, now it seems to be gone. It's kind of a street(forum) cred identifier, always handy to have (or at least the ratio to messages is a good indicator).
I’ve always wondered, given what we know about human decision making and group influence, whether a ‘like bias’ exists on ASR:p
Matias
São Paulo, Brazil
AdamG
Moderator
Reality
Propheticus
Vleuten, Netherlands
2 guesses at possible reasons for column differences:
- old cache with previous stylesheet
- responsive design ....responding to different resolution / available width.
raistlin65
Grand Rapids, MI
Yep. And with responsive design, CSS support can be slightly different between browsers, making things act just a little differently between them.
voodooless
voodooless
Netherlands
Om my 4k screen with Brave it's two columns even when spread wide. There seems to be a maximum width that prevents more columns, so I would guess other browsers/screen combinations should also be fine now.
Propheticus
I had not applied the column fix to all the templates. Those of you who saw one or three columns, can you please report back if that is still the case?
With dark template:
Under 1130px available width (eg phone screen) 1 column, which is fine. From 1130px and up it's 2 columns now. No more 3 columns even when going wider.
@voodooless indeed, using browser developer tools shows a max width of the content body is 1200px with 10px padding.
Grid items have a minimum width of 550px and 10px spacing between them.
3x550(+2x10spacing+2x10padding) does not fit in 1200, making 2 the max.
(This also explains the 1130px switching point; 2x550+10spacing+2x10padding)
