Did you check ipv6 for your switch ?
I am living in France and ipv6 is not available from all the service providers here.
You can also ask some online support from Neumann.
Go to their homepage (with a pc, for whatever reason it does not work with my Android devices), click on the orange bubble in the bottom right corner, then "start a chat instead" and then "connect me to an agent".
I tried yesterday and they gave me the support I needed.
Thanks. Until now I did not know there is such possibility. My browser was set to block third party scripts/cookies so I had no orange bubble on the bottom. Maybe I am blocking too much sometimes.Go to their homepage (with a pc, for whatever reason it does not work with my Android devices), click on the orange bubble in the bottom right corner, then "start a chat instead" and then "connect me to an agent".
What do you mean connecting the KH750 directly to the conputer?Hi!
My new KH 750 is not recognized in the network by the MA-1 Alignment Software (1.4.1.813). I tried everything I could for the last 24 hours : switch on/off / reset / Network mode / Standby off / osx firewall off / etc...
At the moment, The KH750 and the Imac are connected to a switch / no other device / no wifi / no internet. Just a switch and 2 cables.
It does'nt work.
I've read something about ipv6 : do some switches compatible ipv6 and others not ?
Could it be the problem ?
Do some people connect the KH750 directly to the computer without any switch ? Does it work for you ?
Is there a way to download previous versions of the software to test if it is better ?
Please Help!
Thanks a lot mate. On a side note, the ability for re alignment without re going through all the measurements is god sent..Hi,
You can't change and it does not matter.
If you had 2 kh 750 then you would have 2 lines, one for the first 750 and another one for the second 750 (kh 750 right subwoofer).
In you case (and in mine), left is just the "default" information.
I know that the iPad app used mDNS/Bonjour for networking, so I wonder if MA 1 does too? Multicast settings on your router can affect mDNS function. Anyone know? Probably one for @jj-wohlgemuth to confirm.Hi!
It does'nt work.
Please Help!
No. Currently fixed to 80 Hz, not changeable. In the early stages they promised this feature, but did not implement it yet. It seems that the algorithm first aligns both sub and mains to the target (full range) and then aligns phase/latency of sub and mains with a fixed crossover at 80 Hz.
See also here: Post in thread 'Neumann KH150' https://audiosciencereview.com/forum/index.php?threads/neumann-kh150.33454/post-1243363 (and follow ups until post #445)
I don't know. It aligns phase and delay automatically, but you could do that manually with EQ APO and REW. It is time consuming, to find the best settings, though. One thing that's Neumann exclusive is the phase linearisation of the analog main monitors (not MA1 specific, but works also with KH750 and iPad). If you need it, if it is audible, i don't know.Re: sub alignment, do you think MA1 does anything tailored specifically to the 750 that you couldn't get from REW or even Audyssey? I have no idea what it might be, but I've read one selling point is accounting for the unique characteristics of each monitor that only Neumann would know. Same for Genelec w/ GLM, but when it comes to subwoofers I'm not sure what's possible (if anything)
Thank you! When can we start downloading the new version of the software?
I think the software is made for PC not for Mac as stated by Neumann. So maybe that’s where your problem lies?
No, it is not avaiable for me.View attachment 226891
Already available.
They changed the web and if you are not registered and logged in, then you see version 1.4 (but cannot download), if you log in then you see 1.5.
