Great! Thanks.Yes, it works without being connected to the network. The MA 1 software doesn't need to be running either. It's all saved directly on the KH750.
Yes.Yeah, it's front LR and surround LR and a sub. Though it seems like in that configuration only the front would use the subwoofer?
5.1 means 5 main channels and 1 LFE channel. The 0.1 channel only contains LFE content. This is a different thing compared to using a subwoofer as a support (3rd or 4th "way") for your main speakers.So in order to get subwoofer support on all speakers I would have to get a center? .
Out of interest: Which version did you use before changing to 2.0? In my case it was 1.8 beta and i wonder if this may be the cause for the problem.Same (macOS). Sent a message to their support portal.
no one has an idea?Hello, is it possible to measure the KH-750DSP individually without speakers, quasi 0.1?
Not possible. (edit: If you mean calibration via MA1 software)no one has an idea?
yes i mean via MA1 software. I have Neumann KH80 L/C/R and KH750DSP @Meridian and calibrating is in this constellation......and of course 4 Sorrunds JBL305 aka 7.1 System.Not possible. (edit: If you mean calibration via MA1 software)
Thats what i also be wondering. The thing is they def. need to release some bigger subwoofers for the homecinema guys & studios because the 750 is just too small if you want to drive the SPL they have in the cinema. Its okey for an small room but i think when you want to get serious lowend + the headroom, something like a KH870 DSP would be an way or something in betweenOk so after some for fiddling I found out that FL and FR have to be bass managed by the kh750 if I want bass when using ASIO and exclusive WASAPI drivers. So plugging the KH 750 into the LFE channel on the DM7 wouldn't be a good idea. But if I got a second KH750 for the LFE channel I could have windows bass manage the surrounds and use LFE without messing with the front 2.1.
Of course, I'm not sure how the new multichannel MA 1 would work with this, but this seems like the best way to get a good 4.1 setup on windows. If I had the surrounds bass managed by the second KH 750 , there would be a better chance it would work with MA 1, but then I think I would miss out of the LFE channel? This would probably be a lot more simple if Neumann released a multichannel DSP subwoofer.
From the perspective of the MA1, I have a stereo front with 2x KH750 and 2x KH310, and a second stereo system with 2x KH80. I use the secondary system as surrounds. I have both systems calibrated independently.
My interface is a RME UCX II. It comes with a great software called TotalMix FX. In Windows, it looks like this (4 mains + LFE):
View attachment 318364View attachment 318384
In TotalMix i can route LFE to front, this looks like this:
When listening to music in stereo, I get full advantage of my 2 subs in my stereo front.
When watching movies, the whole bass content from L+C+R+LFE comes from mains + subs, only surround content comes from the KH80, which is fine. I don´t need WASAPI or ASIO for this.
BTW i absolutely hate that whole LFE drama in mixes, especially surround music. You never know what amount of LFE is correct.
I practically never listen to surround content actually, because the bass never sounds correct. So i am probably not the best example.
But you had to make new measurements then? Or what do you mean with "previous measurements"?reeinstalling an older version deleting all previous measurments and then installing the newest version did the job no crashing anymore
I don't know, but I have the same issue.Yesterday I updated the firmware of my subs to version 1.2.4. Today I tried to connect to them remotely via the Nuemann Control App via iPad running iOS 17.0.3. The program finds subwoofers on the network, but cannot select them. When you click on the line with the name of the subwoofer, an orange rectangle on the right is highlighted, but the checkbox itself is not activated. On the previous firmware everything worked fine. Does anyone know how to fix this?
Maybe they disabled support for Neumann Control app.Yesterday I updated the firmware of my subs to version 1.2.4. Today I tried to connect to them remotely via the Nuemann Control App via iPad running iOS 17.0.3. The program finds subwoofers on the network, but cannot select them. When you click on the line with the name of the subwoofer, an orange rectangle on the right is highlighted, but the checkbox itself is not activated. On the previous firmware everything worked fine. Does anyone know how to fix this?
This is known issue with almost all MA1 versions - incompatibility with previous versions. Terrible.reason for the crash was the measurements that i got saved on the ma1 software.
so i first deleted all measurements that i got saved on the ma1 software. then i deinstalled the version and installed the newest version and like that it worked for me. had i not deleted the saved messurments the ma1 update would have crashed still
