Not sure if i understand you question correctly.Cool, thanks!. Another question, the sub and speakers should go directly into the AVR and MA 1 will still work properly? RIght now I have the speakers connected to the sub and the sub connected to a preamp. When calibration is done the speakers are connected the to the sub, and when using the AVR the speakers go into the AVR and the sub goes into the AVR (via the right input based on the manual). MA 1 would still work?
Right now the MA1 supports only stereo setups with or without sub. You can calibrate 2 stereo systems and afterwards connect them like a 4-channel surround system (4.0 signal channels going into 2.1+2 speakers) The sub will play bass for front channels only.
Or do you want the AVR to distribute the bass of all 4 channels to the sub, so you have a 4.1 system?
I don't know if this works, depends on what the AVR does exactly.
You could calibrate Sub+fronts and sub+surrounds, so the 120II, 80, and 750 will be configured rolling of at 80Hz crossover frequency.
Or you could calibrate 120II plus sub, then disconnect the sub, calibrate 120II solo, then 80 solo. 120II and 80 will be linear down to their deepest frequency and the sub will be also calibrated, but still be rolling off at 80Hz. I don't know what happens if you calibrate the 4.1 system at last again with the AVR. Maybe it works, but i don't know.
