Several companies offer new boards without having to buy entirely new unit. That's more eco-firendly.I was talking about hardware upgrades. A new version of HDMI requires a new HDMI input/output board.
It does not work like that anymore in modern entertainment based on TV or PC, as digital lossless audio must be carried via either HDMI or DisplayPort. Other digital connectors do not have enough bandwidth for lossless audio. Video can be set for pass-through only and then there is minimal processing, to extract audio only.That's why I think av pre should be audio only, like older ones you used coaxial from dvd to av pre, then s-video or component from dvd to TV...if you upgrade tv to component what the av pre has or hasn't got for video doesn't make a difference
Correct. My Panasonic blu-ray player has a second audio-only HDMI output. This makes it possible to send video to a tv and lossless audio to a prepro. The optical out doesn’t pass lossless.It does not work like that anymore in modern entertainment based on TV or PC, as digital lossless audio must be carried via either HDMI or DisplayPort. Other digital connectors do not have enough bandwidth for lossless audio. Video can be set for pass-through only and then there is minimal processing, to extract audio only.
Would still needs some measurements even if I took a chance at that price.XXL-PREVIEW: IOTAVX 17-Kanal-Vorstufe AVX17 – Hightech-Prozessor mit Dolby Atmos und DTS:X – AREA DVD
Exklusiv haben wir schon erste Höreindrücke von der neuen IOTAVX17 AV-Vprstufe für 1.799 EUR sammeln können - hier folgt bald eine Vorbesteller-Aktion auf HiFiwww.areadvd.de
For the price and a gamble, I can understand that compared to what's out here.I bought the tonewinner at-300 unheard and without measurements. It's a good AV pre.
As for "that price" it's a bargain at that price.
I don’t really see the appeal here vs something like a Denon x3700 or if you waited for the x3800. With the X3800 I believe you get 4 independent sub outputs and sounds like you can either stick with Audyssey or upgrade to Dirac. And you can use all, some, or none of the included amps. In addition you get a ton of features and stability.I've been toying with getting either the IOTAVX 17 or the Tonewinner. Both very similar but the IOTAVX 17 does offer the extra xlr sub outs with individual eq for each one, as well as the pc usb input which would allow the processor to be used like an audio interface/sound card and allow even more flexibility. So possible it may be worth the extra £200 just for those features. For the Tonewinner you don't get the usb input and would need an external minidsp or similar for more than 2 subs to eq them separately which would bring it up to a similar price.
And room correction.I don’t really see the appeal here vs something like a Denon x3700 or if you waited for the x3800. With the X3800 I believe you get 4 independent sub outputs and sounds like you can either stick with Audyssey or upgrade to Dirac. And you can use all, some, or none of the included amps. In addition you get a ton of features and stability.
As i'm currently making do with an old Nad processor, i kinda wanted to stick to the pre-pro thing as I have enough external amplification and wanted balanced xlr for my amps without having to spend an extra £2k for an Anthem or similar. So yes being a cheapskate it did look like an option but yes it does lack a lot of the nice features those Denon's have especially the x3800 so I will keep an eye on that one too.I don’t really see the appeal here vs something like a Denon x3700 or if you waited for the x3800. With the X3800 I believe you get 4 independent sub outputs and sounds like you can either stick with Audyssey or upgrade to Dirac. And you can use all, some, or none of the included amps. In addition you get a ton of features and stability.
This is necessary for a multi channel processor, to get automatic delay, signal power and EQ matching.
Hi there everyone, so what does the IOTAVX AVX17 exactly sound like can anyone compare it to Denon 4700 or lets say Marantz pre pro or even Anthems or Arcams. And also how is the music quality when streaming via bluetooth adaptor.
