The ‘800’ uses the PCM1690 (and not the PCM5102) which also is used in the Onkyo TX-RZ50. There it performes similar to the AKM DAC in the ‘3700/4700’, from a THD+N perspective that is. In the Onkyo it performs better than its spec’s but it does the same in some tests performed by ‘user22’ in the ‘800-thread’. In all cases the performance is >94 dB. The amps however are in both 800 versions poor and way below the DAC’s.
That would be good news, but are we sure the unit that Amir measured has the PCM1690 or the AK4458? I am wondering this because like D+M's Onkyo might have the AK4458 in some of their units manufactured before a certain date due to supply issue as well. This DAC chip thing is getting silly now that manufacturers don't even tell you what they use anymore. That being said, probably most people don't care which one they use, but those who care about measurements apparently do.
For one thing, I noticed that according to the manual, the RZ50 supports DSD up to 11.2 MHz, that is good too, no D+M models, not even the $5,000 AV8805A can play DSD 11.2 MHz native. That's same as Yamaha's.
TX-RZ50 specs:
DSD (.dsf/.dff) • DSF/DSDIFF/2.8 MHz, 5.6 MHz, 11.2 MH
vs D+M's:
DSD 2.8/5.6 MHz 2-channel – .dsf/.dff
