auraluxstudio
- Joined
- Oct 22, 2020
- Messages
- 101
- Likes
- 112
There's an MA 1 2.2.1 download now. Maybe this fixes the issue.I had the exact same thing with my KH150 (connected to the other speaker) since the update to 1.1.10
This topic on the KH150 has been covered on this site, the problem is i don't remember where, use the search. The answer might be different of what you expect, because implementation is key on these subjects, answer will vary depending on the specific gear used, in that specific case you have to keep in mind that your digital signal will be downgraded to 48kHz if higher. I didn't use both (I only use analog, which sounds great to me) but some people who actually did have claimed they were surprised to like the analog input better however counterintuitive it might sound.Some people insist on using a digital interface to connect the KH 150 compared to an analog interface. Is there a difference in audibility?
did this go anywhere - did you have to return the speaker? (oh its a deleted account....)Have had these for about three weeks replacing yamaha hs8. To me there's an incredible improvement with many sound details/instruments being way more audible than on the hs8. Strings particularly sound absolutely beautiful, didn't think a flatter frequency would affect it so much but there it is. I feel like I can work with string samples and sounds way longer before getting annoyed than with hs8. I expect MA1 to do magic once that arrives. Though like half the reason for ditching the hs8 was their self generated noise and prone to interference noise all being too loud.
The kh150 were completely silent which was such a relief, and instruments fading into pure silence was absolute bliss, until unfortunately one of the monitors started to emit a faint fizzling or crackling sound from the tweeter heard up to 1.5m in silence, while the other monitor is still silent. Has anybody else had this with a neumann monitor and should I just get a replacement? I've tried all the typical stuff of swapping and removing cables etc it happens when it's connected to any socket. Sometimes it disappears for a while and comes back later. Tried moving all the rear switches.
Additionally, something my hs8 never did, both the neumann monitors will a few times over the day randomly emit a popping or crackling sound. Thinking it was in the music I played it back and it did not repeat. Only one monitor does it at a time.
did you end up finding out more about the source of the problem?Well, all I can say is that Neumann response was quick. @schallmauer contacted me over PM and asked for the KH150 serial number so they could get it back from Sweetwater to their facilities in Germany for testing. Did they get the defective KH150 from Sweetwater for testing? I have no idea but at least they showed interest in finding the root of the crackling noise issue.
No I did not. Replacement speaker have been working without any issues since I got it about 16 months ago. Most likely was a software/firmware glitch.did you end up finding out more about the source of the problem?
good to know - thanks very much.No I did not. Replacement speaker have been working without any issues since I got it about 16 months ago. Most likely was a software/firmware glitch.
Gen's for me because Glm is such a great software + Sub integration is flawless + Aluminum enclosure.Hi, I'm hesitating between this one and the Genelec 8350, the price difference is significant, are the 8350s worth it?
Translated by moderator. Please post in English going forward. Thanks!
Why?Imaging should better on Neumann though
I think big midbass driver and tweeter integration is worse than smaller midbass + tweeter integration when it comes to imaging...Why?
Soundandrecording has measured both with comparable methods. You may auto translate and compare both reviews.Hi, I'm hesitating between this one and the Genelec 8350, the price difference is significant, are the 8350s worth it?
It depends very much on your room. In a lot of smaller rooms there is a more or less severe dip around 70-100Hz. This area is pretty important ("kick") and a sub may help to fill this. If your bass is pretty smooth from the lowest frequency of the 150 upwards, a sub is much less relevant (depends on the music you are listening).Have many on this thread gone from stand-alone KH150s and then added the KH750 sub? Can you please share your thoughts?
If I'm honest, I'm perfectly happy with the bass output of the 150s but was curious to know how much the sub adds. If it's very little, I'll more than likely pass. I'm kind of hoping it is as I don't like the thought of doing room calibration again.
Thanks DJ, I have no idea if my room is lacking in that frequency range. One thing I did notice the other day actually was that if I sit back on the sofa which is just over 1 meters further back from where my office chair listening position is, the bass seems much more prominent. I did wonder if this is because I lied when room calibrating the system. I have a 49inch monitor on my desk and my listening position isn't 49 inches back from my speakers, so had to bring that distance in a bit (seemed a bit inflexible due to equilateral triangle requirement). Either way, they still sound great, it was just an observation.It depends very much on your room. In a lot of smaller rooms there is a more or less severe dip around 70-100Hz. This area is pretty important ("kick") and a sub may help to fill this. If your bass is pretty smooth from the lowest frequency of the 150 upwards, a sub is much less relevant (depends on the music you are listening).
Having different bass levels depending on the listening position in the room is perfectly normal because of room modes. This is why the measurement mic has to be where you are typically listening, so it can adjust the speakers for that position in the room. If you use the MA1, you can make two sets of measurements and alignments (chair and sofa), if you want.Thanks DJ, I have no idea if my room is lacking in that frequency range. One thing I did notice the other day actually was that if I sit back on the sofa which is just over 1 meters further back from where my office chair listening position is, the bass seems much more prominent. I did wonder if this is because I lied when room calibrating the system. I have a 49inch monitor on my desk and my listening position isn't 49 inches back from my speakers, so had to bring that distance in a bit (seemed a bit inflexible due to equilateral triangle requirement). Either way, they still sound great, it was just an observation.
I probably won't bother as I expect the gains will be very small in comparison to the additional cost. The 150s certainly don't lack bass on their own.
I added the KH750 later to my KH150s. I do not think that it makes a noticeable improvement to my system...Have many on this thread gone from stand-alone KH150s and then added the KH750 sub? Can you please share your thoughts?
