I am about to buy a pair of Neumann KH 120 II or KH 150 for my living room, mainly SACD and high-res streaming at moderate levels, which will be mounted on original wall mount brackets and measured with the MA 1 microphone in the listening position.
The listening distance: 3.5 meters between the monitors and 5.0 meters from the wall where the monitors will be to the listening position.
I know the measurements of the ‘listening triangle’ are not ideal, but this is how it has to be and this can not be changed.
I am aware of the KH 150’s 5 Hz lower range and 0.7 dB higher SPL. For my setup, these are subtle differences which I am in doubt about, whether the +70 percent higher cost of the KH 150 can be justified.
Can you share some thoughts about these possible setups in my living room?
And, also the differences between these two monitors in my living room?
Thanks.
Thanks.
