NAD C 316BEE V2 Integrated Amplifier Review
Rate this stereo amplifier:
    Votes: 4 1.3%
    Votes: 49 16.4%
    Votes: 193 64.8%
    Votes: 52 17.4%
This is a review and detailed measurements of the NAD C 316BEE V2 integrated amplifier with phono stage and headphone jack. It is on kind loan from a member and costs US $399.
The unit feels just heavy enough to not feel cheap. Controls have a nice feel and can be managed with a remote control. The rounded front is a bonus touch in this budget oriented category. Bakc panel shows nice speaker binding posts and a hard power switch:
NAD C 316BEE V2 Integrated Stereo Amplifier with Phono Stage back panel review.jpg
It is basically the modernized version of amplifiers we used to buy 20 to 30 years ago with that captive power cord and such. No, I don't miss those units with the cardboard back panels and cheap RCAs.
NAD C 316BEE V2 Amplifier Measurements
I adjusted the volume control to get nominal 25 dB of gain and ran our standard dashboard:
NAD C 316BEE V2 Integrated Stereo Amplifier with Phono Stage Measurement.png
SINAD is a mix of power supply spikes and distortion, bringing it slightly above average among all amplifiers tested:
Zooming in:
Noise performance very good, sitting where I would expect it to:
NAD C 316BEE V2 Integrated Stereo Amplifier with Phono Stage SNR Measurement.png
Would have been nicer if both channels produced 96 dB at 5 watts.
Multitone test shows lack of rise in distortion with frequency which is nice:
NAD C 316BEE V2 Integrated Stereo Amplifier with Phono Stage Multitone Measurement.png
That is reflected in better than expected performance with 19 and 20 kHz tones:
NAD C 316BEE V2 Integrated Stereo Amplifier with Phono Stage 19 20 kHz intermodulation distort...png
Frequency response is flat and extended:
NAD C 316BEE V2 Integrated Stereo Amplifier with Phono Stage frequency response Measurement.png
Crosstalk is again, what I would expect to see in this class:
NAD C 316BEE V2 Integrated Stereo Amplifier with Phono Stage Crosstalk Measurement.png
Let's see how much power we have into 4 ohm load:
NAD C 316BEE V2 Integrated Stereo Amplifier with Phono Stage Power 4 ohm Measurement.png
NAD C 316BEE V2 Integrated Stereo Amplifier with Phono Stage Max and peak Power 4 ohm Measurem...png
I was shocked by how much power it produced in our peak measurement so ran it again and it was the same. Very nice although the amp did go into protection after above test. Testing the same with 50 Hz still give us what the spec says:
NAD C 316BEE V2 Integrated Stereo Amplifier with Phono Stage Max and peak Power 4 ohm 50 Hz Me...png
We match spec with 8 ohm as well:
NAD C 316BEE V2 Integrated Stereo Amplifier with Phono Stage Power 8 ohm Measurement.png
Sweeping frequencies shows very predictable response. Something we expect in class AB amplifiers but don't always get it:
NAD C 316BEE V2 Integrated Stereo Amplifier with Phono Stage Power 4 ohm vs frequency Measurem...png
Notice how it managed to go into clipping many times without shutting down. Many amplifiers, especially Class D ones, will go into protection at higher frequencies. Not here.
Warm up was uneventful and unit was ready on power up:
NAD C 316BEE V2 Integrated Stereo Amplifier with Phono Stage warm up Measurement.png
Power off may create a pop as is typical in many amplifiers:
NAD C 316BEE V2 Integrated Stereo Amplifier with Phono Stage Pop Nose Power On Off Measurement.png
NAD C 316BEE V2 Phono Stage Measurements
There is no pre out so I had to measure this input using amplifier output. This combines the amplifier noise and distortion with the phono stage, making it hard to compare to dedicated phono preamps. But here we go anyway:
NAD C 316BEE V2 Integrated Stereo Amplifier with Phono Stage Preamp Measurement.png
Fortunately that doesn't impact the frequency response measurement given the flat response of the amplifier by itself:
NAD C 316BEE V2 Integrated Stereo Amplifier with Phono Stage Preamp frequency response Measure...png
This is an excellent implementation!
NAD C 316BEE V2 Headphone Output Measurements
Here is our usual dashboard:
Lots of power supply noise indicates the classic implementation of tapping power amplifier output to feed the headphone jack. :( To reduce the total power a series 68 ohm resistor is in the path which will mess with the frequency response of any headphone that doesn't have a flat impedance. On the positive front, power output is decent:[NOTE: company webpage spec is wrong. Output impedance is 68 ohm, not 8]
NAD C 316BEE V2 Integrated Stereo Amplifier with Headphone Power 300 Measurement.png
NAD C 316BEE V2 Integrated Stereo Amplifier with Headphone Power 32 Measurement.png
Many times when I am testing an audio product, I am surprised by the data I get. Not here and I say that as a positive. This is a budget stereo amplifier from a major brand. I expect to see precisely the performance I showed above. All measurements point to competent implementation despite the low cost and typical margins these companies require to stay in business. The headphone output is a miss but that is very typical for a traditionalist design. If you want to a modestly powerful integrated amplifier using Class AB topology, you have found it in C 316BEE V2.
I am going to recommend the NAD C 316BEE V2 integrated amplifier.
Thanks for the review.
I have no experience with this one, but I used to own its bigger brother, the NAD C 326BEE. I liked its simplicity and ease of use, and sound was perfectly fine, but I had a couple of concerns/complaints with it.
One, it ran really hot - hotter than just about any amp/receiver I've ever owned. It didn't create any problems, but it was a little disconcerting. I definitely didn't want to put anything on top of it.
Two, a minor but important complaint I had was about the volume control pot. It was really quiet at with the knob around 7 o'clock and really loud with the knob around 9 o'clock. Just moving it a little changed the volume a lot, but then after about 9 or 10 o'clock, it was already so loud that it barely got louder. And if I used the remote to control the knob, it was extremely touchy because of this (would go from too soft to too loud with a slight touch of the volume up button). I really felt like they needed a different potentiometer with a different gain curve.
Considering the price, a great product. And for many (me included) a better choice than say the Yammie 701 which, better looks aside, is a fail on the phono stage.
Also love to see mainstream integrateds and amps back in the review rotation. Keep em coming.
Agreed. I also believe the 326 freq response isn’t as flat as the 316.
Oh, and one other thing I remember noticing, something that wasn't a problem with real-world use but was a little surprising nonetheless:
When I had a source active (like a CD being played into the CD input), if I switched to another adjacent input, I could hear the CD very faintly on the unused input. Yes, I had to put my ear fairly close to the speakers to hear it, but I was still surprised that this much crosstalk was happening between inputs.
Nice!
What did I buy 15 years ago? The V1 version? It looks identical as far as I recall! It was a gift, so I can't check.
Edit: what the h... this is not just fine... this is a great amplifier! :)
V2 adds phono input but removes tape monitor in/out connections. There may be other small changes too.
(edited to correct typo from 'phone' to 'phono' :facepalm:)
Now that's what NAD became famous for: A nice integrated amp with good measurements and a complete set of electronics in one compact, affordable box. This is a great buy for someone starting out in the hobby. It will give years of trouble free service and do everything (even though the headphone amp is not the best). Just the thing to take to your dorm room to pair with a PC and a pair of mini-monitors to provide sound for movies and music. And given the modest price of the electronics, a splurge on the speakers could indeed become possible.
This amp did get warm on the left side where the power supply and amplifier heat sinks are. So definitely not cool like a class D would.
Warm during testing and/or warm at idle? My 326 runs hot most of the time.
Boy, does this remind me of my old NAD 3020 integrated. That amp had 20 watts a side with switchable soft clipping, minimal controls and a relatively plain fascia.
But it got the job done. It was actually working when I traded it in way back when, which is something you can't always say with budget gear.
I don’t see phone overload data. Have I missed it?
In common with many integrated amplifiers and all in ones on the market, this unit does not have pre-out or power in sockets. This means that DSP boxes or subwoofer crossovers at line level cannot be patched in. Back in the day, even a $300 pioneer receiver would have such sockets.
This is the unit that I sent. Thanks, Amir, for testing it! I bought this unit before discovering ASR, and what a real treat that it measures decently. I currently pair Fosi V3 monos with EVO 4.4s in my main setup, but it’s nice to know I can swap this NAD in if ever needed. I was also excited to see the headphone jack measurements, as I’m going to try it with my headphones for times when the speakers are prohibitive. Glad to see it was a good deal!
