@DonH56 @Ron Texas This is now with both monitors moved back half way between my desk about 17 inches from the wall. The speakers sound so much more defined bass is tight and punchy. So putting the speakers closer to the wall closed that 50-80hz gap alot. Do you think I could get any better than that if I move it even more to the wall? They are front ported so maybe it will be ok? There is still the boosted freq but the room correction brings that down.
I'm with
@Ron Texas: the "after" plots are very good. I suspect, as others mentioned, that they are extrapolated (calculated) and not actually measured but if it sounds good I'd quit futzing and enjoy.
The LF nulls you probably cannot do much more about unless you move the MLP. Moving the speakers boosted the 65-90 Hz region (though EQ reduced it back), exacerbated the 100 Hz null, and does not appear to have done a lot for the hump above 100 Hz. Moving them further back is OK since they are front ported, but I suspect will not improve things, and may sound worse because other boundaries may be closer. You can always try and see.
I do not know ARC, but most correction systems have almost infinite attenuation ("cut") but only 10 dB or so of boost, so correcting peaks (by attenuating them) is not hard but boosting nulls very difficult. This is a good thing, as boosting a null caused by a room mode or SBIR will make the sound very boomy elsewhere and wastes a LOT of power (a 10 dB boost requires 10x the power), for little improvement. A null from cancellations means direct sound D and reflected sound R cancel: D - R = 0. If you boost the null by a factor or 10, the reflection is also boosted, so you get 10D - 10R = 0 -- still a null, only now you are wasting 10x the power.
If you really want to check the "after" measurements, I suggest picking up a UMIK-1 (~$100) or other measurement mic and downloading REW (free) to do your own analysis. Much more revealing, but also a much deeper rabbit hole...
HTH - Don
