After spending the last months with the Platinum 200 3G, I can now share my 2cents.
Firstly, it's safe to say that they are very good speakers ... SOTA? maybe not, but close and good enough for me to buy them; at least until I move into a bigger room.
My current room is around 22m2 and they fit perfectly being very compact for a floorstand.
I have 1.5m from the front wall, 1m from the side walls and 1.5m the wall behind me.
Is the best position for soundstage, not for the bass but that's why I use subs+EQ
I use Artnovion room treatment in the forms of hybrid absorbers, diffusers, wall bass trap and corner sub bass trap.
The electronics are Node streamer optical out to Denon 3700 (the original) and Nad C298 power amp with Purifi modules.
In the near future most likely I will shift to Pioneer Elite 805 or Onkyo RZ70 for the benefit of Dirac and Bass Control.
The Platinums are built like a tank, soooo heavy for their size, with solid reinforcement inside and thick baffle; also the drivers have huge magnets and beefy motors.
Bellow some measurements from alpha-audio.net regarding the THD.
The crossovers have high quality components and all the cabling inside is silver plated.
The new AMT tweeter is amazing with great resolution and detail retrieval without being fatiguing or harsh and the integration with the midrange is spot-on, seamless transition; the midrange sits in its own aluminum back box filled with absorption material.
The bass is great for the size but not that important for me because I use them with the supplied port plugs and crossover at 80Hz to dual SVS SB3000.
They look amazing with that shaped cabinet, curved front baffle, great painting and lacquered to perfection.
Imaging is solid with good wide and fairly deep soundstage. The overall presentation is not razer sharp, like I experienced with Kef, but bigger and more opened.
The overall tonality is almost flat without sounding boring or dull.
Comparing them with the Gold 200 is not even close; although the overall presention is similar, the Platinum wins on all aspects: imaging, soundstage, bass extension, midrange clarity and top end sparkle and resolution.
Worth mentioning I went back and front between these and Kef Reference 3 for the final purchase battle.
Both are great speakers, with a different presentation, different strong points and weekneses; A plus of linearity for Kef, more pin point stage thanks to the uni-q coaxial driver but I choose Platinum because they're much smaller and fit better my room and their sound is slightly more engaging for whatever reason...maybe wider dispersions or more energy in the midrange - treble.
For sure in a bigger space I would go with Kef ... so maybe next time they will be the winners.
Bellow some measurements in my room. Speakers only and speakers + 2 subs + EQ
Not the final result but sounds pretty good already.
Now I m thinking of adding the center channel...should be a valuable addition and maybe shift my music listening from stereo to Auro 3d upmix in a 5.2.2 set up when I update the receiver also.
