I adjust it's pFd to my liking. Flat or not.
I try not to set pF by ear unless I cannot get access to specs to model, as it can lead to madness and audiophilia nervosa.
So speaking of modeling...
Using the
Hagerman calculator, here are the results I get for the resonant frequency of the Nagaoka MP-500, assuming:
--720 mH inductance of my MP-500 is true to factory spec
--58 pF of my SME tonearm cable is true to factory spec
--Devialet can bet set to loading increments from 0-700 pF in 100 pF steps
And the corresponding optimal resistance loadings, predicted by the calculator, are:
111.4 kOhm @ 58 pF
67.5 kOhm @158 pF
52.8 kOhm@ 258pF
So...
58pF and 158 pF have the least intrusive resonances in the audio band (especially with my hearing rolling off at 15kHz).
But 258 pF is closest to the 47 kOhm resistance the phono stage is set for.
Shall I pick the "Goldilocks" option of 158 pF that is close on the resistance load?
Or go for 58 pF and try to add load resistors to the phono inputs?
