A Dynamic Hybrid Approach
This method uses a high performance audio system as the core left and right speakers and subwoofer, and seamlessly integrates it into a multi-channel home theater system. The Dirac Live room and system correction utilized in the audio system is carried over to the home theater experience.
The first step is to build your stereo system, including setup of all crossovers, delays and Dirac Live projects. This ensures your stereo 2.1 or 2.2 system is fully optimized.
Next, the audio video system is built around the stereo system with its center and surround speakers. The audio of the AVR needs to be set up with the main left and right speakers at full range, so that when the home theater calibration procedure is performed the full audio spectrum is covered. After the home theater system has been integrated and tested with the stereo, the entire system is calibrated by your AVR using Audyssey, ARC, YPAO, Dirac, etc.
When functioning as a stereo system, the AVR/AVP and associated center and surround speakers are removed from the equation. Digital sources are streamed directly into the 2.1 or 2.2 system for a pure and unadulterated stereo listening experience.
For movie night, the AVR/AVP utilizes the stereo system as its main left, main right and subwoofer speakers. In movie mode, the entire system is calibrated by your AVR using Audyssey, ARC, YPAO, Dirac, etc.
Using an AVP with miniDSP SHD and Separate Power Amplifiers
In the example below, the front left and right line level speaker outputs are connected to the two stereo inputs on the miniDSP SHD. The SHD then handles the crossovers between the active subwoofers and main left and right speakers, as well as applying Dirac Live room correction. The AVP is set for large full range speaker with no subwoofer.
Diagram 1. High-end hybrid home theater stereo system with AVP, balanced interconnects and external power amplifiers.
Direct stereo music sources, including streaming services like Tidal or Qobuz, can be streamed internally from the SHD. Or, music from a network area storage device, CD player or Roon can be incorporated as high definition audio sources for stereo listening.
An Affordable System Built with an AVR and miniDSP Flex
This example uses the more affordably priced AVR with built-in amplifiers and the miniDSP Flex in a single-ended configuration.
Diagram 2. An affordable system built with an AVR, miniDSP Flex and power amplifier.
Utilizing both AVR and miniDSP Flex to Drive Separate Subwoofers
This example splits the subwoofers between the AVR and the stereo’s miniDSP system, and may be required in some setups where the main speakers cannot be configured as full range. It also may provide additional flexibility desired by the user.
Diagram 3. Utilizing both AVR and miniDSP Flex to drive separate subwoofers.
Completing the Setup and Calibration of Your System
The order in which the system is setup and calibrated is important. First the core stereo system is setup and calibrated using REW and Dirac. Here’s our Tech Blog detailing that process:
Simplifying the Science of Subwoofer Integration
After confirming that the stereo system is optimized, you will connect it to the main outputs of your AVR/AVP and begin calibration of the home theater system using your preferred AVR correction process (Audyssey, ARC, YPAO, Dirac, etc.)
The stereo system is viewed as a pair of perfect front main speakers by the AVR/AVP.
Please refer to the examples listed above when selecting the speaker type configurations. At this time you will select a nominal level for the SHD such as -10 dB. Once this step is complete, continue with your AVR or AVP correction process.
Switching Between Stereo and Home Theater Mode
There are two settings you need to make on the miniDSP SHD from either the front panel or remote control. First, set the SHD master volume. For example, -10 dB or the setting prior to performing your home theater correction process. Next, you will select the analog input from the AVR/AVP to the SHD, either analog RCA or Balanced.
When it's time to go back to stereo listening simply select whichever direct digital source you like, such as Roon, TIDAL Connect, your NAS, CD player, etc. If a turntable is part of your stereo setup, you will need to connect it using a phono preamp with an analog output that is alternate to the one you are using for the AVR/AVP connection.
