I have a whole post on this thread on how it is possible integrating the SHD with an AVR. When running in HT, you fix the SHD's volume and make it a slave to the AVR. When running stereo, you can still use the AVR as the main processor, or use one of the digital inputs on the SHD to make it the main processor. I don't see how the NAD has an advantage.
I've read that post and also asked minidsp support. It is not possible to use the SHD as a streamer/preamp and as bass manager for the AVR. You cannot switch set its analog input to a fixed level. If you set its master volt to -10dB when watching a movie, you must remember to turn it down to a comfortable level before using it as a streamer...
Agreed! I also use the SHD in combination with an AVR and bypass all SHD channels when I do 5.1 audio. Very happy with the results.I don't think it is a good idea to place the SHD in the chain because it digitizes the analog signal and adds delay.
I've seen numbers in the 20ms range. A true HD bypass product is can provide no delay and unity gain with little or no degradation in SINAD.
- Rich
You need to change your phrasing because you can't say it can't be done when I have gone and done it myself. Yes you have to be mindful of the volume set on the SHD when using it with an AVR and when using the SHD on it's own. It has a large screen and remote volume control so it is really not hard to adjust on the fly. Just fix the volume on the SHD and then use the volume on your AVR.I've read that post and also asked minidsp support. It is not possible to use the SHD as a streamer/preamp and as bass manager for the AVR. You cannot switch set its analog input to a fixed level. If you set its master volt to -10dB when watching a movie, you must remember to turn it down to a comfortable level before using it as a streamer...
The delay the SHD adds is 26ms without DIRAC enabled and 14ms with DIRAC enabled. If your AVR has 30ms or more of configurable delay, then you can time align everything perfectly. The A/D/A conversion isn't a big deal. I wish Amir tested the quality of the A/D conversion but audibly it is very hard to distinguish any differences.I don't think it is a good idea to place the SHD in the chain because it digitizes the analog signal and adds delay.
I've seen numbers in the 20ms range. A true HD bypass product adds no delay and provides unity gain with little or no degradation in SINAD.
I tested both the DDRC-24 and SHD with an external audio interface and a round trip latency program. I also performed another test using acoustic timing measurements in REW. I recorded a baseline using only the Motu M2. Then added the MiniDSP's inline with the M2, and then compared the difference in delays to find the delay of the MiniDSP's.Those delay numbers seem counter intuitive, where are they sourced?
I just tested this with a factory reset. I've also tested in the past with crossovers enabled to subs and speakers and the measured delays were still the same.Is the SHD without Dirac with no processing enabled, for example, after factory reset?
The Dirac result is surprising. Thanks for testing.I just tested this with a factory reset. I've also tested in the past with crossovers enabled to subs and speakers and the measured delays were still the same.
Sorry Ive kind of lost track. Are people with neo3 able to use the usb to trigger power amps? If so might be worth selling my neo2 and getting a neo3
I'm obviously not Amirm, but that question has been answered in this thread. The hardware was updated/changed end of year/first of year (can't remember the exact date). If you go back a few pages, you can see the part that was changed, and it has no affect on the sound. The firmware and software have both been updated in both hardware versions (although they are not really what miniDSP label as "versions"). I believe the only difference from the previous to the current is the USB 5-volt power is constant on in the previous units, and turns on and off with the remote power on and off in the current model.@amirm A simple question, is the update of MiniDSP SHD a firmware update or actual hardware update?
