Has anyone seen a review of the MiniDSP SHD? Obviously this thread provides measurements but I don’t think I’ve ever heard anyone talk about how it sounds?
Here you will find most will think there is correlation between measured performance and sound quality. The SHD is at that point where it is basically transparent. Sounds great as you would expect.Has anyone seen a review of the MiniDSP SHD? Obviously this thread provides measurements but I don’t think I’ve ever heard anyone talk about how it sounds?
Agree... can't really see where there is anything to review outside of what has been done. It has lots of features and it does not alter the sound (unless you want it to with Dirac Live), nor is there any audible noises/distortion from the unit, thus it does not hinder any of the finest details and clarity that you might enjoy in the finest of systems. Sure... elite reviewers could put their own spin on all of it, but the end result will be the same.Here you will find most will think there is correlation between measured performance and sound quality. The SHD is at that point where it is basically transparent. Sounds great as you would expect.
I have inserted a Minidsp SDH in my system since October 2019 and in the configuration intended only for listening to 2 Ch music, it directly drives (through the XLR outputs), two McIntosh MC601 amplifiers, which are connected to a pair of B&W 802D2. Do you want to know how it sounds, or more precisely how it is able to make my room sound through the correction of the DIRAC system? Simply beautifully! When listening to some of the best Female Vocal Jazz albums, (a genre that I particularly love), you can catch the sound of the singer's tongue movements or the moment she inhales the air before leaving with a solo ... well it means that the your system is able to focus on sound details that are not always easy to introspect. Every now and then I try to turn off DIRAC and the sound slime in the bass area comes back to remind me that these were the best € 1500 spent (together with the money for the acoustic treatment of the room), in my 40 years of HiFi purchases. Before the SDH I had an OPPO Sonica dac (which I had modified in the power section and other fields) that in the medium-high part of the musical information, if it played on a par, but the cleanliness made by DIRAC in the low and medium-low area (in addition to the correction of the problems deriving from an asymmetry of construction of the listening environment) are unrivaled, the basses no longer have strange tails and both the instruments and the voice in those areas are more focused. A further fact convinced me of the goodness of the SDH minidsp ... the new acoustics encouraged me to listen to a large part of my music collection, discovering in many cases pleasant news !!Has anyone seen a review of the MiniDSP SHD? Obviously this thread provides measurements but I don’t think I’ve ever heard anyone talk about how it sounds?
Forgive me if am asking a stupid question but how significant is the lack of MQA in the minDSP SHD. This is available in the NAD C658 but it would seem from the measurements that this has an inferior DAC to the SHD. So how does one judge which is more significant? Appreciate your thoughts.
If you are worried about returns, I think you can order from deercreekaudio. They charge a bit more but I believe they have a 30d return policy (please check their website).
I use the minDSP SHD with my TV using optical out, run Dirac, and while the sound from the speakers is slightly behind the TV inbuilt speakers, personally I don't find a disturbing lip sync issue if the TV speakers are turned off.
My replacement power supply is an Alaska and scheduled delivery shows as 2/17.
Apparently, traveling by dogsled,
- Rich
Do I understand correctly that miniDSP is having people like you and @Aventador_SVJ with the brand new Neo3 hardware revision to go into the unit and replace the power supply yourselves?
I asked miniDSP about the new hardware and reports that the ethernet connection breaks in standby mode, requiring a power cycle to restore it. I wanted to understand if that was normal or a fluke. They replied, “We're looking into it but note that this current firmware stopping the standby mode is just a temporary solution while they wait for a new power supply (Already shipped last week). Standby mode will be re-enabled again and everybody will be happy forever after.”
So once you guys get your new power supplies installed, they will update the firmware so that the units go back to operating in a true low power mode. How many of these bad power supplies are out there though?
I take their reply generally to mean that ethernet may be behaving poorly in the “temporary solution” v1.25 but should be fine on the next revision.
@deercreekaudio can you confirm that your new units don’t have affected power supplies? We’re not talking about old units here with @RichB and @Aventador_SVJ . If I understand the timeline correctly those are from early January, purchased direct from miniDSP.
I received my new power supply board today for my SHD and it looks quite a bit different to the previous one (quite a few components have changed).
With the latest firmware (Rev 1.15 / FW 1.25 / 26 Jan 2021 (minor)), it results in slightly more power when 'on' (15w) and in 'standby' (12.6w), than the old power supply (power 'on' = 13w, 'standby' = 10.8w)
MiniDSP have stated that they bring out some new firmware in 2 weeks to work with the new power supply, which will aim to bring down the standby power to similar levels as the previous firmware (Rev 1.15 / FW 1.21 - this caused pretty loud buzzing on my original power supply, Note: power 'on' = 13w, 'standby' = 1.3w).
Fingers crossed, the buzzing won't return, once the power in standby is reduced.
Correct, I received mine in January and purchased directly from MiniDSP.
I have the original firmware and new power supply. Standby is 1 watt and powered on settled in at 13 watts, so no change for me. Power usage may depend on the features enabled.
- Rich
I have an old hardware unit and a new hardware unit. I am using Roon Ready (developer) and not Roon Bridge... on both units. LAN is my only source. I also get the popping noise with the new unit on anything 24bit or higher, but no issues on the older unit. I have a support ticket open with miniDSP right now for the new unit. In the meantime, I'm using the old unit, as I can't handle that popping noise.
It would have to be a Roon/miniDSP compatibility issue due to the "latest" hardware/software updates, because I use the same Roon on my other SHD with no popping. I swapped them out yesterday, same config... back to back... one pops, the other does not.I haven't heard any popping noise but I don't use Roon (despite me still being on a 3 month trial).
I use Tidal/NAS mainly with 24 bit music files and a Nad C298 power amp.
I wonder what is causing your issue......Roon?
