OK - I completely misunderstood.If we're talking about what I said earlier, it's
AVR sub pre outs > radial j+4* > trs flex > sub amps > subs
I had a few minutes to test the Flex last night. I can confirm that it was okay to keep the Flex volume at 0 as my main AVR volume is relatively so low. In fact, I even ran the Flex input gain at +12 and it was all good. Wasn't anywhere close to clipping the flex.
As as my usage goes, it'll be hard to actually clip the Flex. But ymmv.
*Converts from unbalanced RCA to balanced xlr and provides ground loop isolation, which is pretty interesting. With everything hooked up, but nothing playing, I'm sitting at -90 input on the flex. Use the radial j+4 to lift the ground and it goes to -100. That difference is very noticable, especially when the room is quiet.
The only thing I'd say then, is with very low level inputs on the flex, you won't be doing your signal:noise ratio much good. The (fixed) noise level now being added to the low signal, then amplified by the sub built in amp. Not an issue though if you can't hear it.
