D
Deleted member 16543
Guest
Interesting. How is it able to separate direct vs. reflected sound at low frequencies? Time domain analysis? And how low of a frequency is it able to measure anechoically (in a typically sized room)?Klippel NFS only uses gating at higher frequencies (set to about 1 kHz in my configuration). Below that, it is actually able to separate the direct sound of the speaker versus reflected ones. As such, it produces completely anechoic response at full resolution.
Even a proper anechoic room at low frequencies is not really anechoic, so the meaning behind my quasi- prefix is to intend that the measurement is not done in a real anechoic room, not to put the equipment you use on a lower rung on the 'anechoic scale'.
