- Thread Starter
- #61
The sound.TBH, I can't tell from your introductory manifesto what you perceived to be wrong, the CD player or the amplifier.
Ok cool.Nothing new to me, I do know about blind testing, perception bias etc. And that certainly plays a role.
I am not entrenched nor defending a certain position. I just know what I heard myself and I am trying to find an explanation for it.
www.audiosciencereview.com
Funny thing, by your description you could have verified 'the sound' with a $30 USB measuring mic, or even a cellphone's mic and free audio analyzer app. Would have taken less than 20 mins of coaxing answers out of ChatGPT.The sound.
I made some essential edits.I am sorry, I restmyChatGPT's case with you if you can't do better than that, I am repeatingmyselfChatGPT: How can a test about amplifiers from 1987 with one Cd player say something about dacs?
#1 Radiation is undetectable for humans, too, yet it can severely affect them, so numbers themselves don't convince me.Ok cool.
Start with this:
#1 measured difference between all (most, I've not read them all) DACs on this site are below human audible thresholds. The differences cannot be heard. Amps less so, but still pretty much.
#2 well designed electronics do not change the frequency response of an audio signal (within audible thresholds). If the FR does not change then you cannot hear changes that are attributed to FR (like 'warm')
#3 people are subject to perception bias
Based on that, the most likely reason we hear differences (and we all do) is #3
Please give me the blind listening test for dacs, if it exists. It would be interesting to have a look at.Catalog of blind tests for instance, DACs, amps, etc.
And Floyd Toole's book I linked, he is a great writer, forums are hard to sort out. But you already said you are pre-aware of all this, like you don't need to read his book.![]()
Catalogue of blind tests
I thought this thread on Head-Fi was a valiant effort to put together blind tests that have been performed over the years. Given that there have been many more (I'm thinking Archimago's tests, among others), it would be fun to open source a complete list...www.audiosciencereview.com
*Entrenched*#1 Radiation is undetectable for humans, too, yet it can severely affect them, so numbers themselves don't convince me.
I'd like to see randomised double blind tests.
I am not saying you are wrong: I am just saying there is not enough evidence to take any stance (or at least I believe so).
... It's worth absolutely nothing.for what it is worth, according to chatgpt:
That's actually one of the (very) few things OP may be correct about. Marantz D/A filters are usually very aggressive on FR and could translate into audible realm :You are incorrect.
Except, that's not horrible sounding. I mentioned filters early, but we rolled right over that in a heartbeat. Would have been interesting to see if OP could hear the difference between filter settings, blind or sighted I don't even care at this point.That's actually one of the (very) few things OP may be correct about. Marantz D/A filters are usually very aggressive on FR and could translate into audible realm :
Marantz SACD 30n Measurements (SACD Player, DAC & Streamer)
Marantz SACD 30n Measurements Hi folks, Here is my objective analysis of the Marantz SACD 30n. This sample in particular has been gently loaned to me by Sound United France directly. It is a versatile piece of gear, being not only a SACD/CD player, but also a standalone DAC and a streamer...www.audiosciencereview.com
Sorry, while nowadays even scientific studies published in famous peer-reviewed journals often lack reproducibility ( https://en.wikipedia.org/wiki/Replication_crisis , https://www.bbc.com/news/science-environment-39054778 ) I certainly don't go by a test an amateur has done at home.This one is well executed, the levels are matched (which is super critical). They documented enough of the test to give confidence that they took seriously the controls necessary to perform such a trial.DAC blind test: NO audible difference whatsoever
(UPDATES BELOW) That blind test was long due, it's now done. Started with a 30$ unit (Fiio) against a 3000$ one (Forssell) and once SPL-matched (massive gain difference), no one could tell the difference in a ABX test. Then, we switched to a different set-up, using a pair of B&W CM9 speakers...www.diyaudio.com
Archimago has level matched files for you to ABX in Foobar, or go and use DeltaWave to directly compare the null output of two DACs.
I think you may be on your own here. I can't see good faith in your posts, and now you have moved from argument by anecdote to argument by analogy.
And you expect me to believe you and your chatbot.I certainly don't go by a test an amateur has done at home.
Merci, but the sound differences I heard between my old ('90s) Sony receiver and my old Akai CD 27 or an old Philips CD player connected to it versus the modern Marantz Stereo 70S amplifier and CD6007 cd player (always using the same loudspeakers: Visaton Tristar 4 ohm) were much bigger than the differences between the filter settings you mention. I tried them but I was unsure whether I could hear a difference between them. So there must be another explanation.That's actually one of the (very) few things OP may be correct about. Marantz D/A filters are usually very aggressive on FR and could translate into audible realm :
No, I don't expect you to believe anything at all, but you seem prejudiced. My husband and I heard a very clear, undeniable difference between the different devices and I am just trying to find a credible explanation. The only thing you are doing is trying to discredit my experience without backing up your opinion/statement with solid proof.And you expect me to believe you and your chatbot.
You have everything you need to investigate yourself.
Goodbye.
Some of us here have worked in ML, AI solution design etc. You are demonstrating a shallow understanding of AI internal functions. Take my advice - only trust the result if you have access to information about the training data and the choices made to minimise bias. AI tools are extremely useful when used in a constrained manner, in the right context. Asking about audio from ChatGPT is an unsafe usage.Brains do work like that: I remember a friend of my brother got beaten up by foreigners and then he started hating foreigners. Learning by experience. Why do you think they use words like "neural networks" and "machine learning"? Mind you, I am not saying AI and brains are the same, but they have definitely things in common. It's just hard to accept for many people I guess.
How can my understanding of AI's internal functions be not shallow if even professionals don't know anymore what exactly is going on in complex algorithms?Some of us here have worked in ML, AI solution design etc. You are demonstrating a shallow understanding of AI internal functions. Take my advice - only trust the result if you have access to information about the training data and the choices made to minimise bias. AI tools are extremely useful when used in a constrained manner, in the right context. Asking about audio from ChatGPT is an unsafe usage.
[emphasis added]Remember, the internet is full of misinformation and disinformation, and these AI systems base their results on what they see on the internet.
Ok, I'll try to address your actual question - an explanation for why your Marantz system sounded so different. Assuming nothing else (source, speakers) changed.Merci, but the sound differences I heard between my old ('90s) Sony receiver and my old Akai CD 27 or an old Philips CD player connected to it versus the modern Marantz Stereo 70S amplifier and CD6007 cd player (always using the same loudspeakers: Visaton Tristar 4 ohm) were much bigger than the differences between the filter settings you mention. I tried them but I was unsure whether I could hear a difference between them. So there must be another explanation.
