Looking for my first pair of good speakers
C
CarlToft
So Focal speakers are cheap where you are? What other brands? Wondering if he could find a pair of discontinued Chora 816's, for a very good price. Do they have to be bookshelf speakers?
Yea there are a lot of them on the second hand marketplace
AlexanderM
They were very well reviewed here by Amir, so you might want to check them out, especially if they fit your budget.
Moonhead
Denmark
Hej Carl.. Jeg vil kig efter nogle brugte speakers fra engelske AVI, de minder meget om Dynaudio Xeo men mere simpel design og betydelig mere neutral lydprofil, eller gå efter en endgame speaker som Neumann KH150, hvis den matcher dit behov.
Translated by Moderator: (Please use English going forward)
“Hi Carl.. I want to look for some used speakers from English AVI, they are very similar to Dynaudio Xeo but simpler design and considerably more neutral sound profile, or go for an endgame speaker like Neumann KH150 if it matches your needs.”
MarcT
East Texas
Since you upped your price range, these are pretty well reviewed over at Audioholics and might match with your large room better than a small speaker.
They also offer the smaller Aurora 700's.
ahofer
New York City
Get Revels. They sound good anywhere.
Septentrio
Portugal
Kali IN-5 or IN-8 v2. Maybe have a look at their subwoofers as well.
Connect the TV to a Topping DAC (ie DX5) using an optical cable and your phone with an OTG cable (if your phone supports OTG).
Matias
São Paulo, Brazil
Neumann KH 150 if your budget allows.
