Yeah it's why went with walnut as well. I was really hoping for a matte gray.I don't get why it always has to be high gloss? Don't these people have oily fingers and dust?
Personally i don't like it aesthetically, but even more of an issue are TV reflections.How often do you touch your speakers? While I hate high gloss finishes on surfaces that need to be touched regularly (looking at you, car manufacturers), on speakers this really is a non-issue for me. A dry microfibre towel will take care of dust and the occasional fingerprint easily.
You don't?How often do you touch your speakers?
I would say they can't be bad, if they measure that nice.Are the speakers also as good in reality as in measurements?
Are the speakers also as good in reality as in measurements? Any hands on experience by real users?
Great to hear. Do you have any experience with Kef LS50(non- metas) ? If so how your R3 metas sounds compared to Kef LS50? I'm curious to know as I'm planning to upgrade to R3 metas. I'm interested to know if the upgrade will be worth?I've had mine since early March. I think they sound very neutral. I've paired them with an ok sub and powered them with a very clean setup. As set up, they produce incredibly articulate, balanced sound with smooth full bass. I'm very happy.
And the pictures?I upgraded from LS50 meta to R7 meta. Certainly the R7 metas are a huge upgrade from the LS50 metas - I would thing the R3 metas would be a lesser upgrade but still likely a significant improvement.
Why on earth would you buy the R11 for listening nearfield?Does anyone know the minimum listening distance for all KEF “R” series? Particularly the r11. I want to use it for nearfield roughly 4 ft or 1.2 m
I can’t find this info for the life of me
I went from Non Meta LS50's to Non Meta R3's. Definitely an upgrade from 2 way to 3 way speakers. Better (mid) bass, and a smoother more full bodied presentation. Used a single subwoofer with both. Sorry but I don't know about the R3 Metas... yetGreat to hear. Do you have any experience with Kef LS50(non- metas) ? If so how your R3 metas sounds compared to Kef LS50? I'm curious to know as I'm planning to upgrade to R3 metas. I'm interested to know if the upgrade will be worth?
Part of the reason is they are half price..Why on earth would you buy the R11 for listening nearfield?
