KEF Q100 Speaker Review
maty
Tarragona (Spain)
One of the mods is the use of this Spanish visco-elastic damping material inside: two layers of Tecsound SY70 as first in my main loudspeakers (sandwich with fiber-glass) many years ago.
[PDF] https://lotus.soprema.fr/www/reftechsop.nsf/($AllByUNID)/5E5A87A76E0804A1C125871E00545B0E/$File/TDS_INSES0002.d.ES_TECSOUND SY.pdf
noviygera
I think the q100 cabinet needs a brace or two and damping (not damping alone). Side walls make a very hollow sound when knocked.
maty
Tarragona (Spain)
Well, with two layers of Tecsound SY70 is OK.
The coaxial speaker is wonderful but KEF saved on the rest by failing in the bass-reflex design. Maybe one day I will build some new boxes with that fantastic coaxial speaker but yesterday I was delighted, excited, listening to well-heard recordings -> they have never sounded so good.
Johnny Cash - American III, Solitary Man and Tom Waits - Alice. Vinyl -> 24/96 FLAC.
Reed
HI,
Here the Optimizer output:
No EQ Spinorama, Score: 5.04
The EQ design, EQed score: 6.33
The LW is boosted so caution applies when play loud to avoid bottoming and destruction of the speaker.
As for the LS50 the speaker do appreciate a slope to achieve its best score.
Code:
Type     Freq      Gain     Q
PEQ      94.5,     2.33,   2.02,...
PEQ     749.0,    -2.10,   5.34,...
PEQ     947.5,    -1.95,   6.73,...
PEQ    1265.5,    -1.89,   5.98,...
PEQ    1675.0,     1.38,   2.09,...
PEQ    3501.0,     1.10,   2.01,...
PEQ    4981.0,    -1.30,   2.97,...
PEQ    6800.0,    -1.35,   3.44,...
PEQ   11265.0,    -1.02,   2.70,...
The updated Kef Q100 EQed Spinorama:
Really similar to the LS50
The Regression/ Tonal, the ON is pretty flat now
The zoom on ON-LW-PIR
Probably better listened to slightly off-axis around 10degView attachment 85294
And the radar comparing the EQ version and the No EQ version:
Decent gains
the rest of the data is attached
Sorry to jump in so late. Do you have a score with EQ and a subwoofer? I have a pair of Q100s in storage that I’m thinking about using in a secondary system. Thanks.
Maiky76
French, living in China
Hi,
All the scores are in the title of the spinoramas graphs.
I reran the optimizer just to be sure...
Both APO config files are attached.
  • Kef Q100 APO NEw EQ Score 96000Hz.txt
  • Kef Q100 APO EQ Score 96000Hz.txt
alex-z
Thought I would show the impact of the KEF provided port plug. It is a low density closed cell foam, I tested at 0, 20, 40, and 60 degrees to keep the graphs legible. Darker colours are with the plug inserted. Apologies for the 250Hz gating, weather did not permit outdoor measurements.
As you can see, the 1100-1500Hz region is smoother due to the lack of port resonance. The speakers sounded noticeably better with female vocals, but there was significant bass loss below 90Hz, as expected. A good candidate for near-field use with a subwoofer and mild EQ.
