I would like to see some ‘before and after’ measurements if you have any.
Not really necessary when you can switch back and forth at the press of a button. And you can make it a blind test by pressing the button randomly so you don't know if it's on or off and then deciding which you prefer. You then have to get up and look at the extremely small display, invisible from my seating position, and see whether SAM is active or not. The improvement in bass extension is quite apparent.I would like to see some ‘before and after’ measurements if you have any.
We could well run some measurements … the debunk the fib or bolster the truth … at least as far as any graph improvement towards the right direction …. 28 they say … definitely nice bass to these ears … enough not to think about a subwoofer , but maybe it’s just 80 cleanAndre how nice to see you here, we can cure you of that terrible affliction!
Very Best,
A 120 and a ls50 available anytimeYes, I would still like to see the actual measurements.
SAM eliminated the need for a subwoofer. It tried another subwoofer after about 5 years, but went back to using SAM.We could well run some measurements … the debunk the fib or bolster the truth … at least as far as any graph improvement towards the right direction …. 28 they say … definitely nice bass to these ears … enough not to think about a subwoofer , but maybe it’s just 80 clean
The ls50 on Sam at very respectable spl ( for night listening that is ) yielded superb bassIt would be reasonable to expect it can achieve similar results to the LS50 Wireless II, which has a bass boost on-board. There's nothing magic here, but it is hard to do in a straightforward-for-end-users way with outboard processing, so it's interesting to hear of a workable attempt being available.
The LS50 Wireless II specs say the -6dB bass extension is 40Hz, compared to 47Hz for the passive version. (No level quoted, but in my experience active-bass-extending KEF things start to bass limit above around 85dB).
I have a UMIK and REW and use it for set-up, but never had the need to use it to measure the effect of SAM.Andre it is so simple to do it yourself :-
1, Buy MiniDSP UMIK-1 microphone
2, Download REW https://www.roomeqwizard.com/
3, Connect laptop to system,
4, Press ‘Measure’ on software.
That’s it.
I think what Keith meant it’s pretty straightforward to use the program which should be … but I reckon I have a problem somewhereI have a UMIK and REW and use it for set-up, but never had the need to use it to measure the effect of SAM.
Demanding measurements of SAM is a bit like someone getting punched in the face and the police demanding to know the terminal velocity of the puncher’s fist. For the person who’s been punched, it’s a somewhat redundant detail.
P.s. Getting meaningful information from REW is not as simple as you describe. The bit that is easy is using AirPlay or Devialet AIR to send the signal to Devialet.
Uh huh, a lot is written, I would just like to see some actual measurements.I have a UMIK and REW and use it for set-up, but never had the need to use it to measure the effect of SAM.
If there is an audible change in the sound that will be evident in the before and after measurements.I think what Keith meant it’s pretty straightforward to use the program which should be … but I reckon I have a problem somewhere
Now … with no Sam the speaker sound rather thin
With Sam engaged the bass is fuller ..
isn’t that something we could see on the graph ? Maybe real time analysis on some bass tracks ?
I can only notice Sam effectiveness in the bass , the rest is pretty much great … no complain there and could easily live with an ls50 if I wasn’t mad enough to buy a pair of speakers every year ( I like to think of myself as a collector )
The reason why I want to use rew on ls50/Sam … is to see what is done at the bass level so I can move the devialet to other duties and replicate with a newer a cleaner amp ( hypex 500 )
It’s strictly curiosity …… ls50/Sam is all one can need at low level in my case
Ah … the 120 is a 120 watts at 6If there is an audible change in the sound that will be evident in the before and after measurements.
The DVLA measures pretty well I don’t believe a NCore based amp would alter the sound.
SAM is correcting the bass response of the speaker using equalisation based on the measured response. I have full range speakers. They don’t need adapting to the room, which was purpose-built for audio and those speakers in particular, and because Devialet Expert has separate room correction software called Sweet Room. It requires UMIX/REW and then you set the equalisation yourself. I used it in my old room, not in my new room.What’s left, really full range loudspeakers which are adaptable to the room?
In this video they show Darko how they measure a speaker, correct it and extend its frequency response by 40hz. See from 17:30. They explain they measure to 1000hz but only profile to 150hz. The measurements are done with lasers, so a lot more accurate than microphones.Uh huh, a lot is written, I would just like to see some actual measurements.
The LS50 at 40Hz? I think the LS50 is a phenomenal speaker, but no way is their strength the delivery of a distortion free 40Hz at SPLs over -say- 80dB. They are much better if paired with a sub that offloads some of the sub-80Hz off them. It's the way I continue to use mine, and I am not in any way someone who enjoys very loud music - but while the LS50 sound imo awesome out of the box, they get even better when you pair them with a sub (some say 2).In this video they show Darko how they measure a speaker, correct it and extend its frequency response by 40hz. See from 17:30. They explain they measure to 1000hz but only profile to 150hz. The measurements are done with lasers, so a lot more accurate than microphones.
youtube]p9Ox3uQyTh8
It wasn't the LS50. SAM is very effective. I think Infinity had an active speaker correction system years go.The LS50 at 40Hz? I think the LS50 is a phenomenal speaker, but no way is their strength the delivery of a distortion free 40Hz at SPLs over -say- 80dB. They are much better if paired with a sub that offloads some of the sub-80Hz off them. It's the way I continue to use mine, and I am not in any way someone who enjoys very loud music - but while the LS50 sound imo awesome out of the box, they get even better when you pair them with a sub (some say 2).
As to Darko, to me at least he doesn't come across as one of the most credible "audio experts" anyhow.
