AnalogSteph
It looks like the weaknesses found are quite typical for a cheap, front-ported monitor:
Internal resonances escaping out the port are always a problem for those. It's not too bad here.
Distortion <1 kHz can have a fair bit to do with the cabinet, which owing to cost restrictions, won't be as dead, well-braced and well-damped as it could be. (Not to mention that damping always means losses and hence reduced efficiency, reflecting in maximum output.)
The distortion peak between 1 and 2 kHz is owed to tweeter excursion, I think, that seems to be crossed over quite low. This is always a compromise between dispersion, woofer distortion and tweeter distortion. Would you rather have 1% of H3 than 2% of H2? Decisions, decisions... (Presumably they did their multitone testing.)
It's interesting that newer shipments of the Kalis seem to have more well-behaved hiss levels. I've read some statements that the JBLs were actually noisier, whereas it used to be the other way round. (Also, it looks like the first shipment to Europe last year contained a lot of duds.)
Overall, I'm not sure whether you can do much better in a dirt cheap monitor. Tackling the resonances would require diverging from a conventional rectangular box shape (and none of them are doing that), and better cabinet build is never cheaper.
