yewneek
Idle thumbs and the devil's work....
I just can't stop tweaking. However much it works, it can always be better. Right?
I've already got, but not yet replaced, the main filter caps for my JVC R-S7 receiver. Upgrading from 8700uF to 10000uF as I can't find the right value that physically fits. I've also got replacements for the rectifier diodes. Specifications met or exceeded.
I've gone with Nichicon FW as they're the ones that came up as suitable for specs and fit. £10 total give or take, another £15 for shipping. Not using Digikey again!
Anyway, what are thoughts on replacing the rest of the electrolytic capacitors?
I'm leaning away from touching the tuner section, but quite happy with the main amplifier, preamp, and phono sections recap. I don't fancy re-aligning the tuner section.
Just going by the Service Manual and making a list, there's 51 electrolytics to replace, but that's including the tuner stage, which I will edit out later when I inspect it internally to confirm.
It's not a rare beast by any degree, and there's plenty around on fleabay. I like it enough to want to bring it back to spec and use much improved modern components.
Thoughts welcome!
GB
Thoughts welcome!
GB
