- Joined
- Mar 30, 2019
- Messages
- 1,318
- Likes
- 2,409
- Thread Starter
- #1,641
can you please clarify what is expected.? Do you mean that the high mass tone arm is better or worse for this cartridge? I notice from your plots that the light arm (Denon 30LII?) gives a rise is bass at 20hz, while the more heavy arm seem to have a drop/irregularity below 40 hz or so
- Aside from the expected low frequency resonance stability the results pretty much match my prior Denon ones
My Ortofon OM10 on Denon 21F shows som erratic behaviour below 50Hz too... is this a "light arm" problem? or..
High distortion !!! Tracks OK 70um
- Info CA TRS-1007
- New OM10 stylus on OM10 1hr,
- Denon 21F
- CAMBRIDGE cp2 RIAA 220pF, cable 125pF, Tascam 144MK2
The same body with original stylus was posted here
Introducing the Phono Cartridge Measurement Library
AT VM95C Notes Cartridge: Audio-Technica AT VM95C Stylus conditionaudiosciencereview.com
Yes, I meant that a higher mass tonearm is better for this cartridge. You are right that the small small rise at 20Hz on the DL-30II with the light tonearm is the result of a cartridge-tonearm mismatch. Unfortunately my results on the appropriate Sony PS-X50 are not helpful for understanding this because the preamp I was using had a high pass filter at 40Hz and is preventing us from seeing the true results at 20Hz. But yeah I would expect the results to be more flat.
As far as your results, I am not so sure it is a result of the tonearm as the rise is within reason to me. Are you snipping the wav files manually? Sometimes when I cut too early or late it can mess with the results at 20Hz. Other than that I don't have many ideas as to what is happening.
