In-between Corning had designed a USB 3 optical cable extension. That one is a must have if you need USB 3 in excessive lengths (there is simply no alternative), but it also has an excessive price point. Due to the simplifed nature of USB 3 format it is much easier to do capacitive coupling of the data lines (that's why suddenly several isolators showed up that can do so), but as USB 2 MUST be supported as well, Corning had to add a full USB 2 solution into a small connector (fabulous engineering work, done in Berlin . It is not fully transparent (shows up as hub). The most disappointing thing here is that the cable includes two thin copper wires that deliver 5 Volt to the female end of the cable, so despite being optical it does not provide galvanic isolation! I was in contact with the developers at Corning and it seemed they simply overlooked that use case. So some people carefully cut the cable's wires and provide the 5 Volt locally to the female socket to have full galavanic isolation. Not me, though, don't want to destroy it...
Hi @MC_RME . There is a similar version to the Corning from Monoprice that does have a 5V female socket. It has received some positive feedback recently on other forums, so I decided to give it a try with my one year old ADI-2 DAC and NUC7I7DNHE.
Unfortunately, I cannot get it to work. Using Windows 10 and foobar 2000, as I have been doing for a long time, the DAC shows 'disconnect' and doesn't show up in the output device drop down in foobar settings. Remove the monoprice and it's there again normally. I also connected my old Sabre USB dongle and that does work correctly with the Monoprice and it's also posssible to move files between my smartphone and NUC.
I would be grateful for any advice. Thanks..
https://www.monoprice.uk/products/m...ck-fiber-optic-slimrun?variant=31452382003287
