Hi all
Just bought an Intona 7055-c from Batronix site
https://www.batronix.com/shop/USB-isolators/Intona-7055-C.html
On the Intona website it is written that this isolator is compatible with 99% of devices.
I did my own testing on different devices. Here are my results.
Warning - all devices described below work normally when connected directly to a computer
Intona 7055-c v2.0.3
1. Cable OEM usb 3.0 usb-a usb-b 3 meter
usb 2.0 keyboard - OK
usb 2.0 web cam - OK
usb 2.0 mouse (a4tech x7) - FAIL (doesn't work at all. no errors)
usb 2.0 mouse + external power (a4tech x7) - FAIL (doesn't work at all. no errors)
usb 2.0 logitech headset h330 - FAIL (windows message 'usb device not recognized' ('device descriptor request failed' error))
usb 2.0 logitech headset h330 + external power - FAIL (windows message 'usb device not recognized' ('device descriptor request failed' error))
usb 2.0 dac FIIO BTR5 2021 - FAIL (windows message 'usb device not recognized', only charging ('device descriptor request failed' error))
usb 3.0 flash - OK
!! usb 2.0 Matrix Element I DAC (main device) - FAIL ('port reset failure' error)
2. Ugreen us210 usb 3.0 usb-a usb-b 1 meter
!! Windows message 'usb device not recognized' without any devices connected ('port reset failure' in the Device Manager).
Then I delete the non-working Intona USB device from the Device Manager (but periodically get this error).
usb 2.0 web cam - OK, but 'port reset failure' message in the Device Manager
usb 3.0 flash - OK, but 'device descriptor request failed' error
usb 2.0 Matrix Element I DAC (main device) - 10% FAIL (9/10 attempts are successful, but always 'port reset failure' error)
Added: sometimes logitech headset start working normally when I manually remove the broken device from the Device Manager and then update the configuration
3. Vention usb 3.0 type-c usb-b 1 meter
Generally the same as Ugreen us210. But 'usb device not recognized' message appears too often
The device appears to be inoperable rather than working. Any ideas what to do with this?
