iD4 & iD14 MK II - Audient updated their Audio Interfaces
Hello, greetings to all
I have an Audient ID14 but it is the Mk1 version
I needed to know if someone can tell me exactly what type of headphone jack it is so I can fix it.
Any kind soul who can help me?
Thank you so much
The latest firmware update for the iD4 Mk2 fixes the loud digital noise issue! From the changelog:
v1.0.10 -Fixed noise issue at 96KHz
I have multiple audio interfaces. I like my Audient iD44 mk II as well or better than any of them.
Hello dear participants!
I am looking for buying audient iD14 mk2, but I have Linux.
Can somebody please share anhy knowledge is it working with Linux please?
Thanks!
I appreciate that you were trying to help, but please read THIS and THIS :rolleyes: and let's stop derailing this thread. Your condescension is also unnecessary.
any forum, it would really do you well to actually read through to get context on what has already been discussed instead of randomly jumping in with suggestions, because chances are, 99.9% of the time, your random suggestion has already been tried and discussed. Case in point, had you done your research, you would've seen that -- YES, I made sure the volume knob *dim audio* function was not enabled, and I own BOTH the 80 and 250 Ohm DT 770 Pros.
Thank you @Bamboszek for proving and supporting my point:
Exactly what I said above -- So thanks again for supporting my point about the detriment of using low impedance cans with a high impedance Audient, and I also appreciate the links you provided.
Also, I was referring to the Post-AKM fire Mk2 iD4, not your Mk1 or pre-AKM fire Mk2 (see both links above or scroll back to page 12). If you read through this thread, you would see that the internals changed after the AKM fire.
Per the above, he is using LOW impedance cans with a HIGH output impedance iD4 Mk2 -- so sound WILL be distorted. Just watch the link I provided above to JK's video on impedance, as he demos it in that video, and you can visually see the distortion of the sine wave he uses when he shows the effects of a high output impedance on low impedance cans.
Look at how high the output impedance of the iD4 Mk2 is.
We don't need to keep discussing this anymore as it's veering off topic, plus @Bamboszek -- you and I are saying the same thing (Don't use low impedance cans with high output impedance interfaces, as sound will be distorted). I've already returned my Audient and I'm just going to go with an amp instead.
Thanks again for all your responses. My personal experience still stands -- Post AKM-fire iD4 Mk2 is not powerful enough to drive 80 or 250 Ohm DT 770 Pros, an amp is still required for this use case.
Cheers
Hi. I am using the ID.4 Mk2. According to this table, if I switch from using the Sennheiser 560S (120 ohms) to the ID14 Mk2, will I get less output power? Should I pay attention to this table? If I had headphones with 150 ohms instead of 120 ohms, would the sound quality be much worse? I really like the ID4 Mk2. Should I switch to the ID14 mk2 for an additional microphone preamp? Will there be an improvement in the headphone preamp, or will it worsen? Normally, doesn't the more expensive option mean better quality? I'm very confused. I am not familiar with the terms you are using here.
Keep the iD4 or get an iD14 or ----- buy an SSL 2 or 2+. With the Audient interfaces you are ok as long as your headphones are at least 80 ohms. I have both Audient and SSL interfaces - they are all excellent.
PS, prop to you for relying on JK's measurements. He is THE expert.
Are the same converters used in the iD44 mkII?
Thank you so much. Can you comment on the general quality of these converters?
I didn't take any measurements. But I think you can focus on the reviews of the respected Julian Krause, because:
1) In the id4/14/44 reviews, the same DAC's - CS43198
2) In the id44 review, ADC - ESS9842QPRO which is a 4-channel brother of the 2-channel ESS9822QPRO.
Yeah.... Julian is the man.
Thanks for the other information.
Just to add another model for discussion, what is the consensus on the new iD24? A step forward? Sideways?
As a side note, the iD48 is spectacular.
Sorry I'm asking this, but I have no knowledge to understand this by myself.
Is ID4 mk2 will sound bad with the 48 Ohm headphones (I have DT770 Pro X LE) since it have output impedance of 22.3 on the table above? Or what will happen if I get this interface and connect my headphones to it?
I have OK dynamic mic and want to connect it and my headphones to some interface to have an upgrade over my built-in Win PC soundcard. I had Focusrite Solo 2nd gen before and have a lot of issues (technical) with it, so now I wanted to switch to ID4 mk2 as my colleagues suggested, but they all have high impedance headphones.
Plz explain me like I'm 10 years old.
Thank you!
Thank you!
It will be ok. Study the comments and reviews by Julian Krause on YT. He is the expert. He would prefer a lower impedance for the output but your phones would be ok.
