ZolaIII
- Joined
- Jul 28, 2019
- Messages
- 4,192
- Likes
- 2,472
I don't believe you can hear the difference between a DAC that gives 100 dB SINAD to the one with 120 dB one and more so if it goes to power amplifier od any sort that will have significantly lower one and by the way you won't go to over 90 dB LPS (that's 10 dB headroom to lose on interconnect cable's with 100 dB one) listing program volume probably never.Im reluctant to use DAC on my PC to utilise high pass on svs. It would most likely make bass better but overall quality worse.
Finally understand what you mean.
In that case I need crossover device that passes digital signal to Hegel and analog to svs (which probably doesn’t exist)
Or better dac at source and pass analog to svs and then Hegel
You don't need anything! Just a half deacent (even one on MB will do) two chanel DAC which you connect to sub, apply filtering on subs DSP (high/low pass) and connect it's RCA outputs to power amplifier analog line in.
