How to set up high pass filter via pc
Diseasex
Hi guys,
I have Hegel h390 that doesn’t support high pass filter.
I just bought subwoofer svs 1000 pro that only has rca input and normal speaker cables input.
What I’m trying to do is use JRiver to set up high pass filter and send signal to subwoofer before it reaches the amp
Is there a way to do this ?
I presume the standard way to plug woofer is to use “line level output” in amp and plug into rca woofer?
raindance
Doesn't seem very logical to remove the low bass before feeding the subwoofer...
D
Diseasex
What I’m thinking, and pardon if it’s completely wrong,
Is to set up pc to send signal 0-50hz to woofer and 50hz+ to speakers. I guess that’s how high pass works ?
ernestcarl
Yeah, not wrong, but I would rather leave the signal processing to my software DSP (JRiver) with its FIR phase linearization capabilities — there’s more freedom to experiment… and not fiddle at the back plate amps of the speakers.
D
Diseasex
Yeah, but I would rather leave the signal processing to my software DSP (JRiver) with it’s FIR phase linearization capabilities.
Ok so what are you saying ? How to set it up the best ?
ernestcarl
Basically the short of it is I just do adjustments right in front of me on the PC based on past raw (unprocessed) measurements taken and collected mostly at the main listening position. I create models and predictions of how it’ll all sum up and save the DSP settings as a preset (or backup file) for easy recall. Run a sweep again later to see if it holds up to verification, then I’m done. Obviously, it’s really all more complicated in reality.
Zoomer
in Jriver: tools/options/settings/DSP & output format/parametric equalizer
There you can create and route your subwoofer signal.
The Jriver Wiki has more info on how this works.
I don't know your Hegel, but you'd need a separate analoge out to go from there to the sub.
D
Diseasex
Right so I need separate dac and jack to rca cable.
Isn’t there woofer I can send signal via Wi-Fi or usb ? Eh
Tom C
Wisconsin, USA
Some subwoofers have a built in crossover. For those, you connect analog output of DAC to the subwoofer using RCA or XLR, and then analog connection from the sub to the input of the power amp for the main speakers.
In your case, JRiver can be configured to use, say, a 4-channel DAC to do the job. Since you want a 2.1 system, you need at least three channels: Left main, right main, and sub that combines left and right.
A lot of subs have two inputs, one for left channel and one for right. In that instance, a 4-channel DAC could be used, with two of the channels going to the sub (low left and low right).
A lot of PC’s have a built in multichannel sound card. If yours does, you can tell JRiver in its DSP section to convert 2-channel sources to 2.1, and you get lots of options for where you want to select the crossover frequency. You then would wire RCA from the back of the PC to left, right, and subwoofer . There are sound cards that use XLR instead of RCA, but they are usually pro sound cards, not the kind most PC’s have.
D
Diseasex
Interesting. Sounds like pc is a powerful device.
Yes I was confused why there are 2 inputs to the woofer as you would only send one channel,
I’m planning to buy second woofer but need to work out the setup and pass on the single one
Kal Rubinson
Industry Insider
NYC
The problem is that you need 3 channels of output from the JRiver/PC and three channels of D/A to drive L/R/Sub. The simplest solutions (which you may or may not find acceptable is to (1) replace the Hegel with an integrated amp that does bass management or (2) add a miniDSP 2x4HD
D
Diseasex
Hmm the miniDSP will make sound worse as it’s only 192khz and would need expensive dac at source rather than use the Hegels (which is very good)
Not sure if that high pass is worth it at this stage
Which bass management amps this forum recommends ?
Is high pass that good versus line output from amp?
Kal Rubinson
Industry Insider
NYC
No DAC needed at the source. Use USB input.
Dunno much about integrated amps but the Parasound Hint6 seems suitable. I am sure there are others.
???? Can you restate?
D
Diseasex
instead of plugging sub via rca/speaker cable and have overlap in sound (that is what is happening in standard setup I assume?) is it as worth it to separate frequencies of speakers/subs?
Kal Rubinson
Industry Insider
NYC
IMHO, yes. Unfortunately, the mainstream stereo audiophile market has not embraced or implemented bass management satisfactorily. IMHO, custom bass management filters and DSP are essential.
phoenixdogfan
Nashville
You could also use a custom software filter. Lupisoft makes Ekio which implements High/Low pass with selectable slopes/filters + PEQ for around $150. Works on Windows but not Macs (at least not natively). Also Dephonica works and is freeware. Uses an Asio sink driver for input, does not have WDM drivers. I use Dephonica, send everything to JRiver via its WDM drivers, and then have JRiver send the data stream to Dephonica via the Asio Sink Driver.
D
Diseasex
Ok I’ll try software based approach tomorrow. Waiting for cables as none are supplied with woofer to my surprise! Couldn’t plug the damn thing
ZolaIII
You need a PC with multichannel analog unbalanced outs and two 3.5 mm to RCA cables.
Plug the cables to PC (as audio codec use sensing) and configure JRiver to 2.1 out (you can remap channels if need be) fead the Hegel with L, R out and sub with L (white) chinc of other one.
In Tools - Options - DSP & output format under Room Correction put crossover for L & R channel to desired frequency and Routing to sub, most times you don't have to change slope filter defaults but play with it (while there put in Distance values for each one as well [phase correction]). Don't forget to enable the Room Correction settings.
In Tools, Options under volume put it to internal volume and enable Loudness (ISO 226 2003) do a calibration to 84 dB average (after you properly set up the sub) with sound meter.
You are done! Now you have sub crossed with proper filters and equal loudness normalization while doing the output level trough PC. Don't worry much about DAC in PC most of them (if there is no problems) push high 90's SINAD at max output level.
Have a nice time.
D
Diseasex
thanks everyone will try that tomorrow. Love my setup!
D
Diseasex
Have a nice time.
sorry why do I need 2x jack to rca exactly? I ordered one!
