Not trying to stir up trouble since there are differing opinions on the topic. I'm trying to understand if something I recently experienced when I changed one of my IEM's cables could actually happen or is it my imagination, essentially looking for a sanity check. Background, recently bought the D50s and the Geshelli archel 2.5, have the Hidizs MS4 and FIIO F9 Pro. Being one who likes to tinker and explore, I bought a pair of KZ SZ10 Pro IEMs and a pair of TRN V80s to add to my collection. At first I didn't like the SZ10's, tremble seemed a little hot and mid-bass was fairly weak. Spent the good part of a week trying different sets of eartips on each IEM and finally found tips that increased my enjoyment of all, especially the SZ10's whose sound moved closer to what I expected, bass improved, tremble softened slightly to a listenable level.
Here is where it gets strange, I bought my wife a pair of Hidiz Rainbow MS1s and converted the to bluetooth. While I was doing my morning listening routine, turned off the amp and DAC off, and for kicks I took the cable from the MS1 IEMs and put them on my KZS10 Pros, a great upgrade since the stock tangle easy and not very long. Turned on the DAC,AMP, played the same song had I just listened to with the KZ's and stock cable. I sat stunned, mid-bass appeared to improve, vocals were more present and cymbals were clearer. First thought, "Couldn't be the cables, something else changed." So I went through everything and found nothing had changed, everything was as it were before I swapped.
I'm baffled, and after reading a few different forum discussions on the subject some say it does make a difference when going from single headed to balanced, but a straight swap from one single ended to another shouldn't make a difference - should it?
Thanks in advance.
Thanks in advance.
