Isn't that just more words, but the same meaning as, when they are far enough away .When the ears cease to be a significant perturbation in the acoustics of the space.
Is there a way to get one without the other?
Had your mind wandered off the question?Bigger cup size
Bigger cup size
The correct listening distance for those is around 100m minimum.Nah, he was thinking about the HD800
That may very well be the wrong conclusion. As long as you perform your listening tests incorrectly (sighted, not level matched, etc.), you are working with faulty data. Your doctor doesn't prescribe medicine for you that way, why would you do that here?With all your explanations I conclude that i always prefer a sound colored to my taste than a transparent sound.
Don't let Prince Charles hear you say that.homeopathy, which has failed every double blind test of its efficacy.
@amirmActually, he (or she) may. France is a hotbed for homeopathy, which has failed every double blind test of its efficacy.
This is the kind of sound that i like.Not Amir but...
Changing back for some days is not A-B testing as you know it is in the chain.
To really find out you must not know what is in the chain.
You need someone else to switch gear (while you do not know it) and keep logs.
This really is the only simple way to AB gear.
I have been satisfied with transparent sound as well as colored sound.
Using transparent equipment ensures me that any 'ill' effects are either in the recording or transducers. Keeps me from worrying about/questioning gear.
Everyone listens to colored sound as no transducer is ever free of distortion and FR anomalies and most pop music has been altered anyway.
Sound can be convincingly good though.
Guitar is meaty
It's distorded but i can hear easily the bass the drums and i like the way trebles guitar bass and battery sound. I guess it's tube distortion that i like.It's definitely heavily distorted. The question is whether you like your gear to distort it even further when you play it back. Can only be answered with a controlled test, but I wouldn't be surprised if you're right to think you do.
I don't understand what you said about pono player.If only this were Neil Young done 192/24 hirez on a Pono player. Ah the satisfaction then.
On the other hand, less meaty, but also less ear bleedingly distorted:
Here is a more meaty version I suppose:
Much nicer choice.
